Deploy & Forget
Set up your BR1 Classic in minutes, and then let it connect your network for years without worry. The current uptime record for a Peplink device is 1,252 days and counting.
Supports Python
GPIO Terminal Block
Small Form Factor
Certified Toughness
In addition to rugged metal enclosure, the BR1 Classic is certified on:
Shock and vibration resistance
(EN 61373:1999, IEC 61373:1999)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo & terms and conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
To help you better understand the powerful features offered the Pepwave MAX cellular router, we would like to invite you to check out our online demo.
Class 1 Div 2 ready
Hazardous locations need connectivity too. Good news for you, the BR1 Classic is Class 1 Div 2 compatible out of the box so it’s ready to be deployed at even the harshest of conditions, providing you with unbreakable connectivity.
#PowerofPeplink in Action
WAN Link Health Check
Bandwidth Allowance Monitor
WAN Port Convertible into LAN PortLAN DHCP Server for LAN Clients
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web Blocking
Complete VPN Solution PepVPN/SpeedFusion
-Hot Failover
-Site-to-Site VPN
-256-bit AES Encryption
-Dynamic Routing
-X.509 Certificate Support *
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoSGlobal Positioning System Integrated GPS
Device Location Map
Fleet Management with InControl 2Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Captive Portal Support Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3*Feature is available as an upgrade.
Product Code
Description
PVN-LC-05
Enables up to 5 PepVPN Peers License Key MAX-LC-DIM
Drop-in Mode for MAX BR1 Series MAX-BR1-ADV MAX BR1 Advanced Feature Pack
ACW-634 Vehicle Cigarette to Molex Power Cable
PSC-201
1-Year SmartCare for MAX BR1 LTE PSC-323
3-Year SmartCare for MAX BR1 LTE SVL-723
1-Year EssentialCare for MAX BR1 LTE SVL-645
2-Year EssentialCare for MAX BR1 LTE ICS-012
1-Year InControl 2 Subscription ICS-024
2-Year InControl 2 Subscription ANT-MB-22G-S-W-6
5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ANT-MB-22G-S-B-6
5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) -
Product Code Region | Carrier Embedded Modem 4G Bands 3G Bands MAX-BR1-LTEA-W-T Worldwide/ CAT-6 1 B1, B2, B3, B4, B5, B7, B8 , B12, B13,
B20, B25, B26, B29, B30, B41
WCDMA/HSPA+/DC-HSPA+:
Worldwide B1, B2, B3, B4, B5, B8
MAX-BR1-LTE-E-T Europe / International /
CAT-4
1 B1, B3, B5, B7, B8, B20, B38 (TDD),
B40(TDD), B41 (TDD)
B1, B5, B8
* China & HK TD LTE are excluded.
- MAX BR1 Classic
- 12V2A Power Supply (ACW-632)
- 1x Wi-Fi 2.4G Antenna (ACW-304)
- 1x GPS Antenna (ACW-232)
- 2x LTE Antenna (ACW-813)
