Compatible With:
Redundant SIM Slots for Multiple Carriers
Redundant SIM slots with automatic switching for reliable network. You can also set the MAX BR1 to automatically switch SIM cards when you’re in danger of exceeding a data cap. It also allows you to travel across borders without changing SIM cards manually.
Use Cases
Enterprise
Military
Government
Compatible With:
Topologies
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD4 MBX supports band 14, providing additional coverage as the situation demands.
Meet Strict Security Compliance
Got a strict no-Wi-Fi security policy? Built without Wi-Fi, the BR1 ENT is a great choice for deployments with compliance requirements.
Terminal Block for Secure Power Supply
The MAX BR1 ENT is equipped with a terminal block for secure power installation.
HighSpeed Primary Line with LTE Backup
In case of a WAN failure, SpeedFusion Hot Failover technology powers the MAX BR1 ENT for instant failover between wired and cellular links as needed to keep your connection stable and fast.
PoE Output Option Available
Cut down on cabling and simplify deployments. With an optional PoE activation kit, the BR1 ENT supports 802.3af PoE Output, so one cable is all you need for both connectivity and power.
Ethernet WAN Ports 1 (GE) Ethernet LAN Ports 2 (GE) Embedded 4G LTE 1 Cellular Modem @
LTE / LTE-A Redundant SIM Slots Yes (( Mini-SIM (2FF)) USB WAN Modem Port 1 Recommended Users 25-150 Router Throughput 300Mbps PepVPN Yes SpeedFusion Hot Failover Yes SpeedFusion WAN Smoothing Yes Drop-in Mode Yes Number of PepVPN SpeedFusion Peers 2/5/20 (!) PepVPN/SpeedFusion Throughput (No Encryption / 256-bit AES) 100 / 60 Mbps 802.1q VLANs Supported 16 IP Passthrough Yes High Availability Yes WAN as LAN Yes Web Filtering Blacklist Lite Power Output 802.3af PoE Output* AC Adapter AC Input 100V-240V
DC Output 12V, 2APower Input | Terminal Block DC 10V-56V 2A Power Consumption Max.: 16W, Typical: 11W, Min.: 8W Dimensions 1.6 x 5.8 x 5.0 inches |
40 x 147 x 128 mmWeight 0.96 pounds |
435 gramsOperating Temperature -40° – 149°F |
-40° – 65°C
Certifications -FCC, CE, RoHS, E-Mark, IC
-RF Port Lightning Immunity: ITU-T K.20 (+/- 1.5 kV)
Warranty 1-Year Limited Warranty @ LTE-A option: 300Mbs / 50Mbs available. (LTE option: 100Mbs / 50Mbs)
(!) 2 PepVPN Peers are enabled by default. Can be increased to 5 Peers using license PVN-LC-05 or to 20 Peers using license MAX-HD-020-SPF.
* Optional PoE Activation Kit is required to activate 802.3af PoE Output.
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web Blocking
Complete VPN Solution PepVPN/SpeedFusion
-Hot Failover
-Site-to-Site VPN
-Hot Failover
-256-bit AES Encryption
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoSGlobal Positioning System Integrated GPS
Device Location Map
Fleet Management with InControl 2Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Captive Portal Support Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Product Code
Description MAX-BR1-ADV
Package includes a software license key for Advanced Car-Fi Roaming; and SpeedFusion and IPsec X.509 Certificate Support
ACW-622
Includes 1x 56V Power Supply
Enables 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
PVN-LC-05
Enables up to 5 PepVPN/SpeedFusion Peers PVN-LC-10
Enables up to 10 PepVPN/SpeedFusion Peers
MAX-HD-020-SPF
Enables up to 20 PepVPN/SpeedFusion Peers
- MAX BR1 ENT
- 12V2A Power Supply
- 1x GPS Antenna
- 2x 2dBi 4G LTE Antennas
Product Code Region | Carrier Embedded Modem 4G Bands 3G Bands MAX-BR1-ENT-LTE-E-T Europe/International 1 4G LTE:
B1, B3, B5, B7, B8, B20,
B38 (TDD), B40(TDD), B41 (TDD)
WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8
MAX-BR1-ENT-LTEA-W-T Americas/Europe 1 4G LTE-A:
B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41
B1,B2, B3, B4, B5, B8
MAX-BR1-ENT-LTEA-P-T Asia Pacific 1 4G LTE-A:
B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
B1 ,B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
MAX-BR1-ENT-LTEA-R-T America/FirstNet Ready 1 4G LTE-A Pro:
B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B14, B18, B19, B20, B26, B29, B30, B32, B41, B42, B43, B46, B48, B66HSPA+:
B1, B2, B4, B5, B6, B8, B9, B19
MAX-BR1-ENT-LTEA-K-T Global *
1 4G LTE-A Pro:
B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B18, B19, B20, B26, B28, B29, B30, B32, B41, B42, B43, B46, B48, B66HSPA+:
* China & HK TD LTE are excluded.
