Use Cases
Maritime
Constructions
Public Safety & First Responders
Quad Cellular and Redundant SIM slots for Multiple Carrier
The HD4 IP67 includes four built-in outdoor 4G LTE/3G modems, each with two SIM slots to support a total of 8 SIM slots. This enables you to use the same or different cellular providers for bandwidth bonding or eliminating blind spots.
Dedicated for Heavy-Duty Applications
The HD4 IP67 outdoor router has a waterproof IP67 metal enclosure that stands up to dust, vibration, and inclement weather. And, it is certified shock and vibration resistant, making it a great choice for construction, drilling, and other heavy-duty applications.
Dust Protection
Shock & Vibration
Water Proof (IP-67 Enclosure)
Case Study. MAX HD Series
The IT / Audio team from RTL Radio Center Berlin was looking for a suitable connectivity solution for their mobile broadcasting studio that flexibly meets the special requirements for external broadcasts. The solution should guarantee uninterrupted transmission through a stable connection.
WAN Link Health Check
Bandwidth Allowance Monitor
IPv6 Support
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
Weighted
Enforced
Persistence
Priority
Overflow
Least Used
Lowest Latency
Fastest Response Time
Global Positioning System Integrated GPS
Device Location Map
Fleet Management with InControl 2Complete VPN Solution PepVPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding
Site-to-Site VPN
Bandwidth Aggregation
Hot Failover
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
X.509 Certificate Support
PPTP/L2TP/OpenVPN Server
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
VRRP HA support
Security Stateful Firewall
DoS Prevention
Web Blocking
Advanced QoS User Groups
Bandwidth Reservation
Individual Bandwidth Limit
Application Prioritization
By User Groups
SIP, HTTPS, VPN QoS
Custom Application QoS
AP Controller AP Controller Support
Wi-Fi Usage Statistics
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
* IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
Product Code Description ACW-107 802.3af/at PoE Injector (to power up the AP One Flex) ACW-112 Waterproof Ethernet Adaptor (learn more) ACW-622 Includes 1x 56V Power Supply and PoE License to enable 802.3at PoE Output (installation guide)
PSC-218 1-Year SmartCare for MAX HD4 LTEA PSC-417 3-Year SmartCare for MAX HD4 LTEA SVL-478 1-Year EssentialCare for MAX HD4 LTEA SVL-487 2-Year EssentialCare for MAX HD4 LTEA ANT-MB-40G-N-W-6 5-in-1 Cellular Antenna System with GPS Receiver (White) ANT-MB-40G-N-B-6 5-in-1 Cellular Antenna System with GPS Receiver (Black) -
Product Code Carrier Embedded Modem 4G Bands 3G Bands MAX-HD4-M-LTE-E-IP67 Europe /
International
4 B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD) WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8
MAX-HD4-M-LTEA-W-IP67 Worldwide 4 B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41 WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8 MAX-HD4-M-LTEA-P-IP67 Asia Pacific 4 B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41 WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
- MAX HD4 IP67
- Waterproof 12V-56V DC Female Connector
- 2x Waterproof Ethernet Connector Kit (ACW-112)
- Mounting Kit (ACW-723)
