Use Cases
Public Safety & First Responders
Passenger Wi-Fi
Telemedicine
Compatible With:
Simplify your Deployments
Cut down on cabling and simplify your deployments with MAX HD2. The HD2 includes a built-in 4-port GE LAN switch, reducing clutter and the need for extra equipment. As well as a terminal block for secure power installation in vehicles and other locations.
802.11ac Wi-Fi AP
Terminal Block for Secure Power Supply
Built-in 4-Port GE Switch
Dual Cellular for Multiple Carriers
MAX HD2 has two embedded cellular modems and dual SIM slots that allows you to use the same or different cellular providers for bandwidth bonding or for eliminating blind spots.
Certified Toughness
In addition to rugged metal enclosure, the MAX HD2 is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
RF Port Lightning Immunity
(ITU-T K.20 (+/- 1.5 kV))
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD2 supports band 14, providing additional coverage as the situation demands.
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With Social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
#PowerofPeplink
Product Code HD2-LTE Ethernet WAN Ports 2 (GE) Ethernet LAN Ports 4 (GE) Embedded 4G LTE/3G 2 SIM Card Size Mini-SIM (2FF) USB WAN Modem Port 1 Wi-Fi WAN [1] Yes Wi-Fi AP [1] Yes Maximum number of SSID 16 Wi-Fi Standard 802.11ac/a/b/g/n 1166Mbps 2×2 MIMO Transmit Power (2.4GHz) 23dBm Transmit Power (5GHz) 21dBm Simultaneous Dual-Band Wi-Fi AP Yes Recommended Users [2] 150 Router Throughput [3] 400Mbps LTE Modems Downlink/Uplink Datarate: 100Mbps/50Mbps LTE-A Modems Downlink/Uplink Datarate: 300Mbps/50Mbps LTE-A Pro Modems Downlink/Uplink Datarate: 600Mbps/150Mbps 802.1q VLANs Supported 128 Drop-in Mode Yes High Availability Yes Web Blocking Yes Web Filtering Blacklist Lite PepVPN Yes SpeedFusion Hot Failover Yes SpeedFusion WAN Smoothing Yes SpeedFusion Bandwidth Bonding Yes Number of PepVPN SpeedFusion Peers 2/20 + PepVPN/SpeedFusion Throughput (No Encryption) | (256-bit AES) 120Mbps | 55Mbps Number of IPsec Tunnels 5 GRE (Network-to-Network) 5 InControl Cloud Management Yes GPS Fleet Management Yes Manage Pepwave AP Series Yes Maximum Number of AP Support 30 Enclosure Indoor Metal PoE Output Up to 4x 802.3af PoE Outputs # Terminal Block Power Connector for Mobile/Vehicular Deployment Yes (DC 10V – 56V) Dimensions (H x W x D) 1.6 x 10.2 x 5.6 inches (40 x 260 x 143 mm) Weight 2.2 pounds (1 kg) AC Adapter AC Input 100V – 240V | DC Output 12V , 3A Power Input DC 10V – 56V Power Consumption 28W (max.) Operating Temperature -40° – 149°F | -40° – 65° Humidity 15% – 95% (non-condensing) Certifications FCC, CE, RoHS
ITU-T K.20 (+/- 1.5 kV). (RF Port Lightning Immunity)
E-Mark
EN 61373:2010 (Shock and Vibration Resistance)
EN 50155 (Railway Applications –
Electronic Equipment used on Rolling Stock)
EN 61000 (Electromagnetic Compatibility)
Warranty 1-Year Limited Warranty [1] The frequency range for 802.11b/g/n Wi-Fi and 802.11ac/a/n Wi-Fi are 2412−2472 MHz and 5180−5825 MHz respectively.
[2] Transmit power can be configured on the Web Admin Interface.
[3] Recommendation for sizing purposes only. No software restrictions applied.
# Optional PoE Activation Kit is required to activate PoE Output.
+ The MAX HD2 comes with 2 PepVPN/SpeedFusion peers by default. With an optional add-on, they support up to 20 peers. -
WAN Link Health Check
Bandwidth Allowance Monitor
USB 3G/4G LTE Modem Support
IPv6 Support
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
Weighted
Enforced
Persistence
Priority
Overflow
Least Used
Lowest Latency
Fastest Response Time
Global Positioning System Integrated GPS
Device Location Map
Location Tracking Data
GPS eXchange Format (GPX)
Up to Seven Days
Complete VPN Solution PepVPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding
Site-to-Site VPN
Bandwidth Aggregation
Hot Failover
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
X.509 Certificate Support
PPTP/L2TP/OpenVPN Server
Local User, LDAP, RADIUS, Active Directory Authentication
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
VRRP HA support
Security Stateful Firewall
DoS Prevention
Web Blocking
Advanced QoS User Groups
Bandwidth Reservation
Individual Bandwidth Limit
Application Prioritization
By User Groups
SIP, HTTPS, VPN QoS
Custom Application QoS
AP Controller AP Controller Support
Wi-Fi Usage Statistics
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Command Line Interface
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Package Content MAX HD2
12V3A Power Supply (ACW-602)
4x 5dBi Wi-Fi Antennas (ACW-341)
1x GPS Active Antenna (ACW-232)
4x 2dBi 4G LTE Antennas (4G LTE)
(ACW-813)
4x Magnetic RP-SMA Adaptor (ACW-800)
1 Pair of Mounting Brackets (ACW-721)
Product Code Description ACW-622 Includes 1x 56V Power Supply
Enables 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
MAX-HD-020-SPF Activates 20 PepVPN/SpeedFusion Peers -
Product Code Carrier Embedded Modem 4G Bands 3G Bands MAX-HD2-LTE-E-T Europe /
International /
CAT-4
2 4G LTE:
B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD)
WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8
MAX-HD2-LTEA-W-T Worldwide /
CAT-6
2 4G LTE-A:
B1, B2, B3, B4, B5, B7, B8, B12, B13,B20, B25, B26, B29, B30, B41
B1, B2, B3, B4, B5, B8
MAX-HD2-LTEA-P-T Asia Pacific /
CAT-6
2 4G LTE-A:
B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
B1, B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
MAX-HD2-LTEA-WF-T America / FirstNet /
CAT-12 / CAT-6
2 Cellular 1:
4G LTE-A Pro:
B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B14, B18, B19, B20, B26, B29, B30, B32, B41, B42, B43, B46, B48, B66
Cellular 2:
4G LTE-A:
B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41
Cellular 1:
HSPA+: B1, B2, B4, B5, B6, B8, B9, B19
Cellular 2:
WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8
MAX-HD2-LTEA-WK-T Global* /
CAT-12 / CAT-6
2 Cellular 1:
4G LTE-A Pro:
B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B18, B19, B20, B26, B28, B29, B30, B32, B41, B42, B43, B46, B48, B66
Cellular 2:
4G LTE-A:
Cellular 1:
Cellular 2:
