Use Cases
Railway Deployments
Transportation
Events & Temporary Connectivity
Dual Cellular and Redundant SIM Slots
Dual Cellular and Redundant SIM slots allow you to use the same or different cellular providers for bandwidth bonding, data overage protection or eliminating blind spots.
Compact and Powerful
The MAX HD2 mini’s compact metal enclosure (1.6 x 5.0 x 5.8 inches), gives you a tough and powerful mobile connectivity solution.
Terminal Block for Secure Power Supply
The MAX HD2 Mini is equipped with a terminal block for secure power installation in vehicles and other locations.
PoE Output Option Available
Cut down on cabling and simplify deployments. With an optional PoE activation kit purchase, the MAX HD2 Mini supports 802.3at PoE output, so one cable is all you need for both connectivity and power.
Meets Strict Security Compliance
Got a strict no-Wi-Fi security policy? Built without Wi-Fi, the MAX HD2 Mini is a great choice for deployments with compliance requirements.
Certified Toughness
In addition to rugged metal enclosure, the MAX HD2 mini is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
RF Port Lightning Immunity
(ITU-T K.20 (+/- 1.5 kV))
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With Social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
#PowerofPeplink
Software Pepwave MAX Firmware WAN Cellular Support for DHCP
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
Weighted
Enforced
Persistence
Priority
Overflow
Least Used
Lowest Latency
Fastest Response Time
Complete VPN Solution SpeedFusion VPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding
Site-to-Site VPN
Bandwidth Aggregation
Hot Failover
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
X.509 Certificate Support
PPTP VPN Server
RADIUS, LDAP Authentication
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
VRRP HA support
Security Stateful Firewall
DoS Prevention
Web Blocking
Advanced QoS User Groups
Bandwidth Reservation
Individual Bandwidth Limit
Application Prioritization
By User Groups
SIP, HTTPS, VPN QoS
Custom Application QoS
AP Controller AP Controller Support
Wi-Fi Usage Statistics
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
* IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
Product Code Description ACW-622 Includes 1x 56V Power Supply
Enables 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
MAX-HD-020-SPF Activates 20 SpeedFusion VPN/SpeedFusion Peers FIPS-LC-HD2-MINI FIPS License for HD2 Mini ECP-MAX-HD2-MINI-LTE-1Y EssentialCare+ (1-Year) for MAX HD2 Mini LTE ECP-MAX-HD2-MINI-LTE-2Y EssentialCare+ (2-Year) for MAX HD2 Mini LTE ECP-MAX-HD2-MINI-LTE-4Y EssentialCare+ (4-Year) for MAX HD2 Mini LTE SVL-431 1-Year EssentialCare for MAX HD2 Mini SVL-531 2-Year EssentialCare for MAX HD2 Mini ANT-MB-40G-S-W-6 5-in-1 Cellular Antenna System with GPS Receiver (White) ANT-MB-40G-S-B-6 5-in-1 Cellular Antenna System with GPS Receiver (Black) -
Product Code Carrier Embedded Modems 4G Bands 3G Bands MAX-HD2-MINI-LTE-E-T Europe/International 2 4G LTE:
B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD)
WCDMA/HSPA+/DC-HSPA+: B1, B5, B8 MAX-HD2-MINI-LTE-MX-T Latin America/Australia 2 4G LTE:
B1, B2, B3, B4, B5, B7, B8, B28, B40WCDMA/HSPA+/DC-HSPA+: B1, B2, B5, B8 MAX-HD2-MINI-LTEA-W-T Americas/Europe 2 4G LTE-A:
B1, B2, B3, B4, B5, B7, B8, B12, B13, B20, B25, B26, B29, B30, B41
2500WCDMA/HSPA+/DC-HSPA+: B1,B2, B3, B4, B5, B8 MAX-HD2-MINI-LTEA-P-T Asia Pacific 2 4G LTE-A:
B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
WCDMA/HSPA+/DC-HSPA+: B1,B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
- MAX HD2 Mini
- 12V3A Power Supply (ACW-602)
- 1x GPS Antenna (ACW-232)
- 2x LTE Antennas (ACW-815)
