CAT-20
BR1 Pro
Here LTE gets Sonic.
Peplink Device
Wi-Fi just got better
Connect multiple devices simultaneously, and experience faster throughput speeds and better bandwidth congestion with the latest Wi-Fi 6, all with less interference.
SpeedFusion Ready
Enable the endless possibilities of SpeedFusion technology just by simply connecting to SpeedFusion Connect from wherever you are.
Performance Boost
The BR1 Pro has been boosted with a CAT-20 modem which can achieve speeds of up to 800% faster than the original BR1 Pro.
Hardcore Capabilities
The BR1 Pro comes equipped with a 2.5Gbps Ethernet port, making it compatible for your network devices to run at their designated speeds without limitations.
Deploy Anywhere
Certified toughness and wide operating temperatures mean you can just deploy, forget, and enjoy the benefits.
  • SoftwarePepwave MAX Firmware
    WAN Link Health Check
    Bandwidth Allowance Monitor
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Load BalancingMultiple Outbound Policy Algorithms
    • Weighted Balance
    • Priority
    • Overflow
    • Persistence
    • Least Used
    • Lowest Latency
    • Enforced
    • Fastest Response Time
    SecurityStateful Firewall
    DoS Prevention
    Web Blocking
    • Site-to-Site VPN
    • 256-bit AES Encryption
    • Pre-shared Key Authentication
    • Dynamic Routing
    X.509 Certificate Support *
    Remote User Access (PPTP/L2TP/OpenVPN)
    Application Prioritization
    • SIP, HTTPS, VPN QoS
    • Custom Application QoS
    Edge ComputingSupport on Applications and Docker (HW3+)
    Device Location Map
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    AP ControllerSupport for Peplink AP Series
    Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi Usage Statistics
    Captive Portal SupportSupport for Wired LAN clients
    Support RADIUS Authentication
    Command Line Interface
    InControl 2 Cloud Management
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    *   Feature is available as an upgrade (MAX-BR1-ADV).
    ^   IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
  • Product CodeEmbedded ModemsRegions 4G Bands3G Bands
    MAX-BR1-PRO-GLTE-S-T-PRM1x LTE-A Pro (CAT-20)Compatibility: Global B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71HSPA+/WCDMA: B1, B2, B3, B4, B5, B8, B9
  • Product Code Description
    ACW-634 10ft Direct Wire DC Cable
    ANT-MB-42G-S-W-6 7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White)
    ANT-MB-42G-S-B-6 7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black)
    LIC-VWAN Activate 1x Virtual WAN
    LIC-2VWAN Activate 2x Virtual WAN
    * Learn more about Virtual WAN Activation License here.
    • 1x MAX BR1 Pro CAT-20
    • 1x 12V2A Power Supply (ACW-632)
    • 4x LTE/5G Antennas (ACW-234)
    • 2x Wi-Fi Dual Band Antenna (ACW-341)
    • 1x GPS Antenna (ACW-232)
