Time and Attendance System
Manage all Information from Single Dashboard
The Pepxim Smart Reader and Time and Attendance System make attendance management into a more than easy process. Employees can easily clock in and out using their NFC cards, while management gains access to an intuitive yet powerful system that provides real-time visibility and significantly reduces administrative workload.
Security. Broad Card Compatibility
Smart reader is compatible with today’s most secure card platforms including several HID iClass and Proxy formats.
Flexible Deployment Options
Traditional systems require local servers and controllers. Deploy Smart Reader across multiple buildings, remote offices, and other mobile locations
Expandable Cloud Platform
TA Cloud allows you to integrate reader data seamlessly into your existing access control or attendance system.
Admin View
User View
Employee Attendance Management System & Software #3
With the TA system, employees can access information about their daily attendance, as well as the status of pending leave requests. With employees able to look up their own attendance information, they no longer need to make inquiries to HR, saving administrative overhead.
Employee Attendance Management System & Software #4
The TA System is accessible from anybrowser. Employees are able to see their attendance record and leave balance. They can also request time record adjustments as needed.
Self Service Leave Requests
Save administrative costs by having employees perform their own leave requests. Once the request has been submitted, all it takes is one click from the manager to have it take effect.
Time and Attendance Mobile App
Review attendance information on-the-go with our mobile app, available for iOS and Android.
Products
Employee Attendance Management System & Software #8
Smart Reader
Reads NFC cards and uploads attendance information to the Time and Attendance System where it can be reviewed via reports and used to calculate payroll.
Employee Attendance Management System & Software #9
MAX HD Series
The Smart Reader can be powered by PoE supplied by MAX cellular routers.
This combination is ideal for vehicular deployments. Receive location information for passengers as they board; useful for big data analytics.
Interested in Time and Attendance System Solution?
  • High FrequencyiCLASS, iCLASS SE/SR, iCLASS Seos, MIFARE SE, DESFire EV1 SE, MIFARE Classic 1K / 4K, Ultra Light, Ultra Light C, Plus (Security Lvl 1) , MIFARE DESFire 0.6, MIFARE DESFire EV1 (MAC / DES / 3DES / 3K3DES / AES), CEPAS (CAN), FeliCa (Idm), PIV, ISO14443B (CSN)
    T=CL, ISO 14443 A with up to 848 kbps transmission rate (depending on card), ISO 15693 with up to 26 kbps transmission rate (depending on card), iCLASS Seos
    Low FrequencyHID Prox, HID Indala Prox, EM Prox, AWiD Prox
    Network1x 10/100M Ethernet Port,
    802.11 a/b/g/n, 2.4/5GHz Wi-Fi
    (as WAN)
    I/O6x I/O (Analogue or Digital, Software Selectable )
    RS-485
    2 sets Dry Contact (NC/NO/Common)
    EnclosureCompact Plastic IP55 Enclosure
    Weight0.45lbs (205g)
    Power Input802.3af PoE or Terminal Block (12-24V)
    Power Consumption13W (max.)
    Temperature Range-40°C to 65°C | -40°F to 149°F
  • Product CodeName Description
    TA-VA-20TA Virtual ApplianceTA Appliance, supports 20 Smart Readers.
    TA-VA-LC-10Extra 10-Reader license For TA Virtual ApplianceEnables the TA Appliance to support an additional 10 Smart Readers.
    TA-10TA Cloud Appliance Annual FeeTA Cloud Appliance, annual fee, supports 10 Smart Readers.
    TA-LC-1Extra Reader Annual Fee For TA Cloud ApplianceEnables the TA Cloud Appliance to support one additional Smart Reader.
    RDR-IW-LCDSmart ReaderSmart Reader with color LCD display.
