InControl API dashboard banner showing total devices, online device count, and a network usage graph.
Bring InControl's Network Management API Into Your Own Platform
Peplink's InControl API gives developers and operations teams programmatic access to network monitoring, device data, and management capabilities, so you can bring Peplink intelligence into the tools and workflows you already use.
What You Can Do
Integrate Network Data Into Your Tools and Workflows
The right API integration means your team stops chasing data and starts acting on it. Whether you're building a custom dashboard, automating reporting, or connecting network health to your existing operations tools, these are the capabilities that do the heavy lifting.
Icon of a location pin with the Peplink logo on a map, representing the real time device map.
Real-Time Device Map
Pull live GPS and location data for all Peplink devices and render them directly in your own platform.
Icon of a circular chart with bars, representing user statistics reporting.
Usage & Bandwidth Data
Access WAN and SIM usage across hourly, daily, and monthly timeframes for reporting and billing.
Icon of a bell above an ascending bar chart, representing bandwidth usage alerts.
Bandwidth Alerts
Track data consumption and configure alerts when usage exceeds defined thresholds.
Icon of an eye with a bar chart inside a viewfinder frame, representing WAN connection monitoring.
Monitoring
Pull live connection status, health, and uptime across your entire device fleet.
Icon of a person beside a laptop showing a bar chart, representing self service data access.
Connected Clients
Access live connected client lists, per-client bandwidth usage, and client counts at both device and group level, useful for capacity planning, troubleshooting, and usage reporting.
Who It’s For
Built for the Teams That Run Critical Networks
InControl API is designed for organizations that need more than an off-the-shelf dashboard. Teams that manage complex, distributed networks and need the flexibility to build around their own workflows.
Network technician checking WAN health on a tablet in a server room.
MSPs & Service Providers
Your Clients' Network Health, Inside Your Platform
Stop jumping between portals to chase status updates. Pull connection health, usage, and device data directly into your own Professional Services Automation (PSA) or portal, with billing and Service Level Agreement (SLA) figures that reflect real-time network performance.
Team reviewing network dashboards on laptops in an office meeting, captioned Enterprise IT, full infrastructure visibility, no extra tools.
Enterprise IT
Full Infrastructure Visibility, No Extra Tools
Keep your entire network in view without adding more tools. The InControl API lets you pull WAN health, device status, and usage data directly into your existing Network Management System (NMS), so you can monitor your entire infrastructure in one place.
Passengers riding a public transit train, captioned Public Safety and Transportation.
Public Safety & Transportation
Real-Time Awareness When It Counts
When a dropped connection has real consequences, your team can't afford to switch between interfaces. Surface live GPS and WAN status directly inside your dispatch or operations platform. No context-switching, no delays.
Go Deeper
More Than Just Monitoring
InControl API also gives you access to deeper configuration and reporting data, so you can build more complete, end-to-end solutions.
Live Bus tracking interface showing real time bus locations and a delay alert on a map.
Advanced Device Management
The Router API unlocks a more convenient way to manage your devices. By combining it with the InControl API, you can execute those same device-level commands remotely, across your entire fleet, from anywhere.
Wi Fi Information interface showing Wi Fi name and data usage over a date range.
SSID Info & Usage
Retrieve SSID details, usage data, and profile information directly via the API, so your team can plan capacity and audit Wi-Fi usage across your device fleet without having to manually pull reports from InControl.
SpeedFusion VPN Status interface showing peer connection and test results.
Access SpeedFusion VPN tunnel and peer connection data directly via the API, so your team can build health checks, automate alerts, and report on bonded connectivity across distributed sites.
Bandwidth Consumption interface showing data usage by Ethernet, Peplink eSIM, SIM pool, and Starlink.
Billing Integration
Pull bandwidth consumption, uptime, and client counts into your billing or Professional Services Automation (PSA) platform. No manual exports required.
Event Logs interface showing time, device, type, and detail columns.
Event Logs
Access device and group-level event logs, including archived logs, directly via the API, so your team can manage compliance, maintain audit trails, and troubleshoot issues from within your own platform.
What’s Possible
Build Smarter Workflows with InControl API Data
Integrating InControl API into your platform unlocks workflows that weren't possible before, enabling more adaptive and automated operations.
Icon of a network router distributing connections to three devices.
Traffic Management
Use WAN status and connection health data to build logic that dynamically adjusts traffic distribution in your own platform, and trigger WAN priority changes without manual intervention.
Icon of a ringing alert bell.
Alerting
Raw network event data from the API gives your team the foundation to build smarter alerting, one that correlates events, reduces noise, and ensures your team is only notified when something genuinely needs their attention.
Icon of a declining bar chart with a magnifying glass and checkmark, representing verified data insights.
SLA Tracking
Continuously evaluate uptime and device performance to track whether SLAs are being met, enabling more accurate tracking and faster identification of potential risks.
Icon of a magnifying glass over a trend line, representing data trend analysis.
Pattern Analysis
Feed historical network data into your own analytics tools to identify recurring issues, helping you anticipate problems and make smarter network decisions.
Map pin inside a geofence boundary icon.
Location Tracking & Geofence Events
Pull device location history from the API into your own platform, and receive geofence events through each fence's HTTP/HTTPS notification, so your systems know when a vehicle enters or leaves a zone.
SIM card with data usage bar chart icon.
Data Usage Reporting
Pull SIM and Starlink data usage per device into your own billing or reporting tools, then match it to your data plans to track costs per site and spot high-usage sites early.
Ready to Integrate InControl into Your Platform?
Access the full API documentation to get started, or reach out to the Peplink team if you'd like guidance on the right integration approach to get the most value from your InControl investment.
