Balance 2500 EC
Edge Computing at Its Peak.
The Premier choice for Edge Computing
Edge computing improves speeds by processing data locally before sending it back to your headquarters. And with 1 TB of built-in storage, this allows the Balance 2500 EC to handle whatever you throw at it.
Ports and Connections
Gallery
Software Peplink Balance Firmware WAN Support for PPPoE, Static IP, DHCP
WAN Link Health Check
PING
DNS Lookup
HTTP
Bandwidth Allowance Monitor
IPv6 Support
USB 4G/3G Modem Support
changeip.com
dyndns.org
no-ip.org
tzo.com
DNS-O-Matic
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted
-Enforced
-Persistence
-Priority
-Overflow
-Least Used
-Lowest Latency
Security DoS Prevention
Stateful Firewall
Web Blocking
Complete VPN Solution SpeedFusion VPN/SpeedFusion Bandwidth Bonding
-Site-to-Site VPN
-Bandwidth Aggregation
-Hot Failover
-256-bit AES Encryption
-Dynamic Routing
-X.509 Certificate Support
PPTP/L2TP/OpenVPN Server
Advanced QoS User Groups
-Bandwidth Reservation
-Individual Bandwidth Limit
Application Prioritization
-By User Groups
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
BGP, OSPFv2 and RIPv2 Support
Bonjour Forwarding
Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage Statistics
Support RADIUS Authentication
Support LDAP Authentication
DNS Built-in Authoritative DNS
-Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Power Requirements Universal Input 100V – 240V AC -
Product Code Product Name Description BPL-2500-EC Balance 2500 EC Equipped with 4x 10G SFP+ ports, 16x (GE) Ethernet ports and 1TB SSD. SFP and Ethernet ports can be configured as WAN/LAN.
Supports Edge Computing. Capable of running Native App (Python), containers (Docker), and hypervisors (KVM).
Product Code
Description
SVL-730
EssentialCare (1-Year) for Balance 2500 EC
SVL-612
EssentialCare (2-Year) for Balance 2500 EC
PSC-190
SmartCare (1-Year) for Balance 2500 EC PSC-390
SmartCare (3-Year) for Balance 2500 EC -
- 1x Balance 2500 EC
- 2x Power Cords
- 2x Rack Unit Rails
- 1 Pair of Mounting Brackets
