Peplink B One Plus in offices
Peplink B One Plus
Peplink
Peplink B One Plus Router Affordable LTE Cellular Backup
Status: Antenna Installed
Stay Connected with LTE Backup Internet
For mission-critical business applications like point-of-sale transaction processing, uninterrupted Internet access is crucial. With Peplink’s B One Plus and a cellular data plan, LTE Backup Internet keeps you connected for critical transactions or voice services when your primary internet connection fails.
What is LTE Backup Internet?
LTE Backup Internet leverages cellular networks to provide an alternative internet connection. When your primary internet service experiences disruptions, LTE backup seamlessly takes over, ensuring that you remain online without any interruption. This solution utilizes the widespread availability and robust performance of LTE cellular networks to deliver reliable backup connectivity.
Benefits of LTE Backup Internet
Uninterrupted Connectivity
With LTE backup, you can avoid costly downtime. Whether it’s a power outage, service maintenance, or unexpected technical issues, LTE backup ensures that you stay connected and productive.
Reliable Performance
Enjoy reliable speeds with LTE technology. This backup solution supports your essential activities, including point-of-sale, cloud computing, and online transactions, maintaining smooth operations even during primary internet outages.
Enhanced Productivity
Keep your business running efficiently with uninterrupted internet access. LTE backup ensures that your critical transactions can continue working without delays, safeguarding productivity and preventing revenue loss.
Wide Coverage
Benefit from extensive LTE network coverage. Whether you’re in an urban area or a remote location, LTE backup provides a reliable connection, making it an ideal solution for varying environments.
Wide Coverage
Cost-Effective
Prevent the financial impact of internet outages. Investing in LTE backup is a cost-effective way to maintain continuous operations and protect your business from potential losses due to connectivity issues.
Cost-Effective
Peplink B One Plus with built-in LTE cellular
B One Plus B One Plus
LTE Cellular Router
LTE Cellular Router
Fast 1 Gbps routing throughput with built-in LTE cellular modem for critical data backup.
eSIM and Dual SIM slots
eSIM and Dual SIM Slots
Bring your own data plans via eSIM profiles or dual physical SIM cards.
Dual WAN
Dual WAN
Supports two separate Ethernet WAN connections in addition to built-in LTE cellular.
SpeedFusion
SpeedFusion
Better than failover or load balancing, bonds all your connections into hyper-reliable connectivity.
Ports
Ports
2x Gigabit WAN ports, 4x Gigabit LAN ports, 1x USB-C port
Dual-Band WiFi
Dual-Band WiFi
Two concurrent WiFi bands maximize connectivity to your devices: 1 band at 5GHz and 1 band at 2.4GHz.
VPN
VPN
VPN supports IPSec, PPTP, L2TP and OpenVPN protocols, as well as Peplink’s patented SpeedFusion VPN for 256-bit AES encrypted high reliability, high security connections.
Firewall
Firewall
Stateful firewall for enterprise branch security with DoS prevention and web blocking.
VLAN Routing
VLAN Routing
Supports VLAN setups with port mapping and and Inter-VLAN routing.
Multiple SSID WiFi
Multiple SSID WiFi
Create up to 16 wireless networks each with their own SSID.
QoS
QoS
Quality of Service features enable prioritizing voice, video and even application-specific connections to improve reliability and overall network performance.
Firmware Updates
Firmware Updates
Firmware updates are supported for the life of the product.
Remote Management
Remote Management
Supports web-based, app-based and InControl cloud-based device and configuration management.
Upgradeable
Upgradeable
Supports and controls additional WiFi Access Point for extended coverage, add additional WAN connection via USB-C port.
With LTE Backup Internet, enjoy peace of mind knowing that your connectivity is secure.
This solution provides a seamless transition to a reliable backup connection, ensuring that your business operations remain unaffected by internet disruptions. Stay connected, stay productive, and experience the benefits of uninterrupted internet access with LTE Backup Internet.
B One 5G
B One 5G Product
Looking for higher-performance backup options?
Check out the B One 5G Router with built-in 5G for more bandwidth intensive applications.
Port and Connections
B One Plus Front
Wi-Fi 6
1 x LTE Modem
USB WAN
B One Plus Back
Dual WAN
Power Port with GPIO
    WAN Link Health Check
    Bandwidth Allowance Monitor
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Load BalancingMultiple Outbound Policy Algorithms
    • Weighted Balance
    • Priority
    • Overflow
    • Persistence
    • Least Used
    • Lowest Latency
    • Enforced
    • Fastest Response Time
    SecurityStateful Firewall
    DoS Prevention
    Web Blocking
    • Site-to-Site VPN
    • 256-bit AES
    Encryption
    • Pre-shared Key Authentication
    • Dynamic Routine
    • Hot Failover, Smoothing, Bandwidth Bonding *
    X.509 Certificate Support
    Remote User Access (PPTP/L2TP/OpenVPN)
    GRE Tunnel
    Application Prioritization
    • SIP, HTTPS, VPN QoS
    • Custom Application QoS
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    VRRP HA Support
    BGP, OSPFv2 and RIPv2 Support
    AP ControllerSupport for Pepwave AP Series
    Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi Usage Statistics
    Captive Portal SupportSupport for Wired LAN clients
    Support RADIUS Authentication
    Command Line Interface
    InControl 2 Cloud Management
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    *   Requires a PrimeCare subscription, complimentary for the first year.
    ^   IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
  • Product CodeEmbedded Modem RegionLTE Bands3G Bands
    B-ONE-PLUS-LTE-US-T-PRM1 x CAT 4North America*
    *US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet
    B2, B4, B5, B12, B13, B14, B66, B71B2, B4, B5
    B-ONE-PLUS-LTE-E-T-PRM1 x CAT 4APAC, EMEAB1, B3, B5, B7, B8, B20, B38, B40, B41B1, B5, B8
    B-ONE-PLUS-LTE-MX-T-PRM1 x CAT 4Latin AmericaB1, B2, B3, B4, B5, B7, B8, B28, B40B1, B2, B3, B4, B5, B8
  • Product CodeDescriptions
    PRM-A-1YPrimeCare A (1-Year)
    PRM-A-2YPrimeCare A (2-Year)
    PRM-A-4YPrimeCare A (4-Year)
    PCP-A-1YPrimeCare+ A (1-Year)
    PCP-A-2YPrimeCare+ A (2-Year)
    PCP-A-4YPrimeCare+ A (4-Year)
    ACW-63410ft DC Power Cable
    ACW-791Peplink 4-Pin to USB-C Power Cable
    ACW-235Indoor LTE/5G Very Wideband Cellular Antenna
    ACW-341Dual-Band Indoor Wi-Fi Omni Antenna in Black (RP-SMA)
    ANT-SLM-22G-S-B-6Slim 22G - 2x2 MIMO Ready Cellular and Wi-Fi Antenna System with GPS (Black)
    • 1x B One Plus
    • 2x LTE/5G Antennas
    • 2x Wi-Fi Dual Band Antennas
    • 1x 12V 3A 4 Pin Power Supply (ACW-672)
