MU – MIMO
MU-MIMO offers significantly increased efficiency to your network. Now multiple client devices can receive data simultaneously through AP One Flex MU-MIMO and beamforming antenna technology, which concentrates and steers radio signals towards specific client devices.
Simultaneous Dual Band
Reduce Wi-Fi congestion and interference. Simultaneous dual-band Wi-Fi on the AP One Flex gives you two independent networks that work together, so all of your devices can connect without clashing.
Waterproof Enclosure
Provide Wave 2 ac Wi-Fi in more places with Flex. The tough IP55 rated enclosure is perfect for outdoor environments as well as other dusty and moist locations.
Boost your Network
Increase your wireless speeds with AP One Flex. Connect your devices with Wave 2 11ac while enjoying enterprise-grade reliability
3-Port Switch
Connect to all of your devices, wired and wireless. Hooking up cameras, video surveillance, and even another AP One Flex is a breeze thanks to a built-in GE port and a PoE input.
User Access Control
Control network access with separate logins for each user group. AP One access points support up to 16 SSIDs, each with independent bandwidth limits and web blocking.
MIMO Directional Antenna
Forget about outboard antennas. The Flex has MIMO directional antennas built right in.
Centralized Management
Configure AP One Flex onsite or from the cloud. Peplink AP Controller lets you locally manage access points from your Balance router, while InControl 2 offers a complete cloud-based solution accessible from any web-browser.
Social Wi-Fi Hotspot
Guests can now access your Wi-Fi hotspot with their Facebook login. In exchange, you can learn more about your customer base with insightful reports
Complete Network Solution
Enjoy better network integration and performance. AP One access points are a perfect complement to Balance routers, together providing blazing speed and superior reliability across your entire network.
#PowerofPeplink
Ethernet Port 3x GE Wi-Fi Standard Simultaneous 802.11ac wave 2/ac/a/b/g/n
2×2 MU-MIMO
2.4GHz * 300Mbps/ac/a/b/g/n 5GHz * 866Mbps Simultaneous
2.4GHz and 5GHz
Yes Wi-Fi Transmit Power 2.4GHz: 20dBm |
5GHz: 21dBm
Coverage (With line of sight in open environments) 2000ft |
609m
Recommended Concurrent Users Per Radio 60 Number of SSID Per Radio 16 Antenna Type Built-In, Directional: 2.4GHz (65° Horizontal x 60° Vertical), 5GHz (70° Horizontal x 30° Vertical) Antenna Gain 2.4GHz: 9dBi |
5GHz: 10dBi
Enclosure Waterproof Outdoor IP55 Dimensions 11.8 x 4.9 x 1.9 inches |
300 x 124 x 47 mm
Weight 1.15 pounds |
520 grams
PoE Input 802.3at/802.3af PoE Output 802.3at ^ Power Consumption 13W (max.) Operating Temperature -40 – 122°F |
-40 – 50°C
Humidity 15% – 95% (non-condensing) Certifications FCC, CE, RoHS * The frequency range for 2.4GHz and 5GHz are 2412−2472 MHz and 5180−5825 MHz respectively.
^ 802.3at output requires the PoE injector (ACW-109), available separately.
Network Bridge Mode
Router (NAT) Mode
Wireless Distribution System (WDS on 2.4GHz Only)
Management VLAN (802.1p)
Spanning Tree Protocol (802.1d)
Radio Multiple SSID
Auto Channel Selection
Transmit Power Adjustment
Neighbour AP Detection
AP Security Open
WPA/WPA2/WPA3-Personal
WPA/WPA2-EnterpriseDevice Management Web Administrative Interface
InControl Cloud Management
SNMP v1, v2c and v3
Client Management per SSID VLAN with QoS (802.1p/802.1q)
Bandwidth Control
MAC Address Filtering
Layer 2 Client Isolation
Limit on Max. Number of Client
Client Management per Client VLAN with RADIUS
VLAN with VLAN Pool
Bandwidth Control
Multicast Filter
IGMP Snooping/Multicast Enhancement
Complete PepVPN Solution Site-to-Site VPN
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
Captive Portal By InControl -
Product Code Description ACW-107 802.3af/at PoE Injector (to power up the AP One Flex) ACW-109 PoE Kit for IP55 Outdoor Products (to enable 802.3at PoE Output on the second port of AP One Flex) ACW-510 Ball Joint Mount for IP55 Outdoor Products. Wall/pole mount with flexible ball-joint for high-precision installation. SVL-743 1-Year EssentialCare for AP One Flex SVL-621 2-Year EssentialCare for AP One Flex ICS-012 1-Year InControl 2 Subscription ICS-024 2-Year InControl 2 Subscription -
Suitable For Product Name Product Code Description Outdoor Installation. Wall and Pole Mount Friendly. AP One Flex APO-FLX 802.11 ac wave 2/ac/a/n 866Mbps and 802.11b/g/n 300Mbps. MIMO directional antennas: 2.4GHz, 8dBi (65° Horizontal x 60° Vertical); 5GHz, 10dBi (70° Horizontal x 30° Vertical).
3x 10/100/1000M Ethernet Ports with 1x 802.3at PoE Output option.
- AP One Flex
- 2 x Plastic Cable Tie
* Power supply or Pepwave Passive PoE Injector are not included
What is the difference between ACW-107 and ACW-109?
Please check with the End User what’s their setting for the application and choose the correct PoE injector
- Standard PoE in (using ACW-107 or other 802.3at injector) can provide ~15W Power range PSE to the APO-FLX IP55
- 56V 2.1A power supply (ACW-109) with Passive PoE injector can provide standard 802.3at Power range PSE
In other words, ACW-109 is not required. But if the End User is aiming for the first case, then they would need to buy ACW-107 (802.3af/at PoE Injector).
