AP One Series
Comparison Table
  • AP One MiniAP One RuggedAP One In-WallAP One FlexAP One AXAP One AX LiteAP Pro AX
    Product CodeAPO-AC-MINIAPO-AC-RUGAPO-AGN2-IW-US/
    APO-AGN2-IW
    APO-FLXAPO-AXAPO-AX-LITEAPP-AX-IP67
    Ethernet Port1x Gigabit Ethernet3x Gigabit Ethernet1x Fast Ethernet Uplink
    4x Fast Ethernet
    3x Gigabit Ethernet1x Multigigabit Ethernet1x Gigabit Ethernet1x Gigabit Ethernet
    Wi-Fi StandardWi-Fi 5Wi-Fi 5Wi-Fi 4Wi-Fi 5Wi-Fi 6Wi-Fi 6Wi-Fi 6
    Data Rates2×2 MU-MIMO
    2.4GHz: up to 300Mbps
    5GHz: up to 866Mbps
    2×2 MIMO
    5GHz: up to 866Mbps
    2×2 MIMO
    5GHz: up to 300Mbps
    2×2 MU-MIMO
    5GHz: up to 866Mbps
    4×4 MU-MIMO
    2.4GHz up to 1148Mbps
    5GHz: up to 2400Mbps
    2×2 MU-MIMO
    2.4 GHz: up to 574Mbps
    5 GHz: up to 1200Mbps
    2×2 MU-MIMO
    Recommended Concurrent Users Per Radio60606060256256256
    SSID Per Radio16161616161616
    Transmit Power2.4GHz: 22dBm
    5GHz: 23dBm
    2.4GHz: 17dBm
    5GHz: 17dBm
    2.4GHz: 17dBm
    5GHz: 17dBm
    2.4GHz: 20dBm
    5GHz: 21dBm
    2.4GHz: 25dBm
    5GHz: 25dBm
    2.4GHz: 24dBm
    5GHz: 25dBm
    2.4GHz: 24dBm
    5GHz: 25dBm
    Included AntennaBuilt-In Omni Antenna
    Antenna gain:
    2.2dBi for 2.4GHz, 3dBi for 5GHz
    2x Dual-Band Omni Antenna
    Antenna gain:
    3dBi for 2.4GHz, 3dBi for 5GHz
    Built-in MIMO Omni antenna
    Antenna gain:
    2dBi for 2.4GHz, 4dBi for 5GHz
    Built-In MIMO Directional Antenna
    Antenna gain:
    9dBi for 2.4GHz, 10dBi for 5GHz
    Built-in Omni Antenna
    Antenna gain:
    5dBi for 2.4GHz, 5dBi for 5GHz
    Built-in Omni antenna:
    Antenna gain:
    2 x 3dBi for 2.4GHz, 2 x 3dBi – 5GHz
    External Omni antenna^:
    Antenna gain:
    2 x 8dBi for 2.4GHz, 2 x 8dBi – 5GHz
    Antenna ConnectorN/A2x RP-SMA ConnectorsN/A2x RP-SMA Connectors (5GHz)N/AN/A4x N-Type Connectors
    EnclosurePlenum-rated, Indoor Plastic Ruggedized MetalPlenum-rated,
    Indoor Plastic Mounts Into Standard US/EU Singe Gang Wall Jack
    Waterproof IP55 OutdoorPlenum-rated,
    Indoor Plastic
    Plenum-rated, Indoor PlasticPlenum-rated, IP67
    Dimensions3.9 x 3.9 x 0.8 inches
    98 x 98 x 19.7 mm
    4.8 x 4.2 x 1.4 inches
    122.1 x 107 x 35 mm
    US: 5 x 3.4 x 2.1 inches
    128 x 86 x 53.5 mm
    International: 3.4 x 3.4 x 2.1 inches
    86 x 86 x 53 mm
    11.8 x 4.9 x 1.9 inches
    300 x 124 x 47 mm
    8.1 x 8.1 x 1.3 inches
    205 x 205 x 32 mm
    5.9 x 5.9 x 1.3 inches
    160 x 160 x 33 mm
    9.0 x 12.2 x 2.6 inches
    230 x 310 x 66 mm
    Weight0.33 pounds
    150 grams
    0.8 pounds
    365 grams
    US: 0.37 pounds
    170 grams
    International: 0.34 pounds
    155 grams
    1.15 pounds
    520 grams
    1.73 pounds
    785 grams
    0.84 pounds
    382 grams
    4.85 pounds
    2200 grams
    Power InputAC Input 100V – 240V,
    DC Output 12V, 802.3af PoE
    (Injector Not Included)
    AC Adapter: AC Input 100V – 240V /
    DC Output 12V 2A, 30V 1A
    802.3at PoE
    48V DC Connector
    802.3af/802.3at PoE
    802.3at PoE+
    (56V Pepwave Passive PoE Input is Needed for full 1x 802.3at PoE+ LAN Output^)
    DC Jack: 12V DC
    AC Adapter: AC Input 100V – 240V, DC Output 12V, 2.5A*
    802.3at PoE+#
    DC Jack: 12V DC
    (Plug 5.5 x 2.1 mm, center positive)*
    802.3at PoE+*
    802.3at PoE+*
    Power Consumption9.5W (max.)13W (max.)15W (max.)22W (max.)23W (max.)14.5W (max.)14.5W (max.)
    Operating Temperature23° – 113°F
    -5° – 45°C
    -40° – 149°F
    -40° – 65°C
    -4° – 104°F
    -20° – 40°C
    -40° – 131°F
    -40° – 55°C
    32° – 104°F
    0° – 40°C
    32° – 104°F
    0° – 40°C
    -40ºF – 149ºF
    -40ºC – 65ºC
    Humidity15% – 95% (non-condensing)15% – 95% (non-condensing)15% – 95% (non-condensing)15% – 95% (non-condensing)15% – 95% (non-condensing)15% – 95% (non-condensing)15% – 95% (non-condensing)
    CertificationsFCC, CE, RoHSFCC, CE, IC, E-Mark,
    Railway Certification: EN 50155,
    Railway Certification: EN 50121-3-2
    Railway Certification: EN 50121-4
    Vibration & Shock: EN 61373
    FCC, CE, RoHSFCC, CE, RoHSFCC, CE, RoHSFCC, CE, RoHS
    Warranty1-Year Limited Warranty1-Year Limited Warranty1-Year Limited Warranty1-Year Limited Warranty1-Year Limited Warranty1-Year Limited Warranty1-Year Limited Warranty
    Package ContentAP One Mini,
    12V2A Power Supply (ACW-601),
    1x Mounting Bracket
    AP One Rugged,
    12V2A Power Supply (ACW-632),
    2 x Wi-Fi Antenna (ACW-342)
    AP One In-Wall,
    Wall Socket Mount Set
    AP One Flex,
    2 x Plastic Cable Tie
    AP One AX,
    Ceiling Mount Base (9/16” T-Rail),
    Ceiling Mount Base (15/16” T-Rail),
    Mounting Screw Set
    AP One AX Lite,
    Mounting Screw Set
    AP Pro AX,
    Water Proof DC Power Plug for IP67 (ACW-636),
    1x Waterproof Ethernet Connector Kit (ACW-112),
    Mounting Kit (ACW-723)
    Remarks^ Available separately.* Optional feature.
    # PoE Injector is available separately.
    * AC/DC adapter and PoE Injector are not included.^ External Omni Directional Antennas are not included in the package.
