![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/600Mbps-Dual-SD-WAN-Router-Balance-One-2.jpg/w=2560)
Advanced Dual-WAN Router for Branch Networking
USB LTE Connectivity
Plug in a USB modem to use an LTE connection for load balancing and failover. The Balance One’s USB port supports more than 250 4G LTE/3G modems used by a variety of carriers worldwide.
Ultimate Performance
Featuring 600Mbps throughput the Balance One keeps connections dependable and fast with automatic balancing and failover between links.
8x GbE LAN Ports
Connect all your devices at high speeds, without complicated setup, or external switches.
Integrated Wi-Fi AP
Balance One gives you two independent networks that also work together, so all your devices can connect without clashing. Recommended Concurrent Users Per Radio is 60.
Enterprise Features
Connect remote clients to your private network using L2TP with IPsec, monitor Bandwidth Usage, allocate bandwidth on application, and more
![600Mbps Dual SD-WAN Router Balance One #3](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/600Mbps-Dual-SD-WAN-Router-Balance-One-3-1.png/w=768)
Balance Portfolio.
SD-WAN for enterprise of all sizes.
Peplink ‘s line of products includes features that make your enterprise deployment easier and increase your network reliability and security in several ways. Boost network data rates, reliability, and flexibility while slashing connectivity costs with Peplink SD-WAN technology designed for multi-WAN link load balancing. Use Load Balancing and SpeedFusion bandwidth bonding to deliver superfast VoIP, video streaming, and data using an SD-WAN enabled network.
![600Mbps Dual SD-WAN Router Balance One #4](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/600Mbps-Dual-SD-WAN-Router-Balance-One-4.jpg/w=992)
Built to Last
Built in AP Controller
Built in AP Controller puts you in charge of all connected access points, create and manage custom captive portals. It allows you to manage your wireless network from your router and easily build a custom captive portal for your business.
![Built-in Software-Based Controller for WiFi Management](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Built-in-Software-Based-Controller-for-WiFi-Management-1.jpg/w=992)
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Cloud-Based-SD-WAN-Network-Management-Solution-InControl-2-1.jpg/w=2560)
Balance One is supported by InControl, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
Web Admin Demo
![600Mbps Dual SD-WAN Router Balance One #5](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/600Mbps-Dual-SD-WAN-Router-Balance-One-5.png/w=992)
#PowerofPeplink
![600Mbps Dual SD-WAN Router Balance One #7](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/600Mbps-Dual-SD-WAN-Router-Balance-One-7.png/w=960)
![600Mbps Dual SD-WAN Router Balance One #8](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/600Mbps-Dual-SD-WAN-Router-Balance-One-8.jpeg/w=992)
![600Mbps Dual SD-WAN Router Balance One #10](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/600Mbps-Dual-SD-WAN-Router-Balance-One-10.jpg/w=992)
![600Mbps Dual SD-WAN Router Balance One #12](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/600Mbps-Dual-SD-WAN-Router-Balance-One-12.jpg/w=992)
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/balance-one-product-index.png/w=992)
