Bandwidth Bonding Site-to-Site VPN and Failover
| Bandwidth Bonding VPN for multiple locations Unlike traditional VPN technologies, Peplink's technology establishes and bonds VPN traffic among multiple connections. Encrypted with 256-bit AES, the Bandwidth Bonding VPN feature allows businesses to connect to multiple locations with military-grade protection. When an Internet connection fails, the VPN failover feature will dynamically switch traffic over to the active connections, maintaining uninterrupted VPN service. | Better Performance Peplink Balance's outbound traffic management feature allows you to prioritize VPN traffic. VPN traffic will have a higher priority and will perform optimally even under heavy network load. |
| Cost Savings The increased reliability, as provided by the failover feature, will allow businesses to switch from expensive leased lines (such as T1, MPLS) to a combination of DSL or Cable. With the VPN functionality built in, business can create a VPN network across multiple locations without the need of extra devices. Peplink offers a full line-up with different capacity, giving you the flexibility to choose the right devices for various types of business locations. | Bond Your Mobile Broadband. Peplink Balance and Pepwave MAX provide support for 4G/3G mobile broadband modems from carriers around the globe. Bonding your mobile broadband provides extra bandwidth and reliability anywhere you need it, allowing you to easily stream HD video or transfer large files when you are on the move. Check out VPN Bonding on 3G for more information. |
| Extreme Security. Peplink Site-to-Site VPN is highly secure. In typical VPN, MPLS, or private leased line, packets are transferred in an orderly fashion over one link. The network is exposed and compromised if an attack is targeted at this particular link. Peplink Site-to-Site VPN, however, constantly scramble data traffic across available Internet Links and encrypts it with unique WAN specific 256-bit AES encryption. Data transfers between sites in the most secure way possible! | Advanced VPN Routing Route data traffic in anyway imaginable. Peplink Balance’s highly flexible WAN traffic routing lets you route specific traffic types from selected sources to a fixed VPN node. You can route Internet traffic through your Headquarters’ Firewall, or route VoIP call to your branch location in Europe! All traffic is managed easily with a few clicks! |
Cutting Edge VPN Technology without Hassle. | |
![]() | Save Money with a Single-Device Complete Solution Separate devices are not needed for extra VPN capacity. Peplink Balance comes with everything you need - both Bandwidth Bonding Site-to-Site VPN to easily connect multiple sites, the PPTP-VPN Server to enable remote access, and IPsec VPN to connect to existing infrastructure. Save money and enjoy all the advantages of all VPN technologies with Peplink |
| Just a mouse click away Peplink Balance is designed for you and is extremely easy to set up. You don't need to be a professional to configure the Peplink VPN settings. Just enter a few parameters and a VPN tunnel will be established. | ![]() |
