Pepwave Surf SOHO
Surf-soho-front
Surf SOHO
3G/4G Wi-Fi Router for Home and Small Office.
surf-soho-auto-failover
Automatic Failover Between:
Surf-soho-ports
Delivers crystal-clear phone calls, flawless teleconferencing, and the assurance that important data takes priority at all times.
pepwave surf soho at home
Built-in L2TP and PPTP VPN server that allows up to three simultaneous VPN connections, including your smartphone and tablet, to keep sensitive information safe.
Fully supports dynamic IP environments and NAT. 100% compatible with SpeedFusion and other Peplink technologies, ensuring fast and flawless connections to all your Peplink/Pepwave equipment.
surf-soho-ru-banner
Router Utility provides information about the device status, events, bandwidth usage, and more. With push notifications enabled, the app can even alert you if a connection fails or if the router loses power or reboots.
See the Surf SOHO Specifications
View
Top
