Balance and Surf Combo
Seamlessly Combine Citywide Wi-Fi and Wired Broadband
Overview
Citywide Wi-Fi networks are presently proliferating across the US, and also beginning to be developed in other areas of the world. Upon the availability of Citywide Wi-Fi, households and small businesses look to combine Citywide Wi-Fi bandwidth with their existing wired broadband Internet services in order to enhance overall Internet service performance and increase availability.
Surf & Balance Combo enables the seamless integration of Citywide Wi-Fi and wired broadband, and consists of one Surf AP 200 unit and one Balance 30 unit. Surf AP 200 is the industry-leading Wi-Fi modem specially designed for Citywide Wi-Fi applications. Balance 30, with functionality aimed at Small Office/Home Office (SOHO) environments, is the entry-level model in the Balance series of Internet Link Load Balance devices.
At a glance, the Surf & Balance Combo works as follows:
  • The Surf AP 200 unit wirelessly connects with Citywide Wi-Fi and as a local Access Point.
  • The Balance 30 unit connects through Ethernet with both Citywide Wi-Fi via Surf and wired broadband via the DSL/Cable modem.
  Features Benefits
Link Aggregation and Load Balance
Faster, more reliable Internet made easy.
Drop-in Mode
Easy, transparent installation
Link Failover Non-stop Internet service even when one of the links is down.
VoIP, SIP, and Vonage® Support Fully compatible with major SIP-based VoIP providers. Enjoy your calls.
Session Binding Compatible with secure web, e-banking, and other applications.
High Power and Enhanced Receiption Get better receiption and increased throughput with you Citywide Wi-Fi network
What is Balance 30? How is it different?
Balance 30 is the entry-level model in the Balance series of Internet Link Load Balance devices. You can compare the functionality of the entire Balance series here.
Datasheets
Post Date Title Type Size Download
Jan 29 2007 Balance 30 Datasheet 224KB
Application Notes
Jan 31 2007 Seamlessly Combining Citywide Wi-Fi and Wired Broadband 877KB
Feb 1 2007 Dual FLASH and the Benefits 208KB
User Manual
Feb 28 2008 Balance User Manual 4.1 3.1MB
Case Studies
Oct 9 2007 TJSC Group Ltd. (London, UK) 725KB
Jun 6 2007 Spleen Web Hosting (Jacksonville, FL) 485KB
Apr 10 2007 Becker Limos (Oxnard, CA) 821KB
Mar 20 2007 Cressida Associates (Haworth, NJ) 520KB
Jan 26 2007 19th Avenue Lofts (Seattle, WA) 449KB
Jan 28 2007 Wisers Information (Hong Kong SAR) 160KB
Looking for Wi-Fi Products?
