Bandwidth Bonding | |
Fill Your Tank with 3G/4G, WiMAX, Satellite, and More.Our unique modular approach lets you strike the perfect balance of connection speed, cost, and availability. Mix and match up to seven wireless links and providers to boost your bandwidth and beat poor coverage. No matter what combination you choose, the Pepwave MAX's intelligent management means it all just works -- and so do you. | Get More Performance and Mileage from Your Connections.MAX bandwidth bonding automatically distributes traffic across wireless links, increasing connection stability and making maximum use of all available bandwidth. And you can scale your bandwidth as you go simply by adding extra 3G, 4G, or other wireless connections at any time. |
Seamless Failover The MAX automatically switches to lower priority connections when primary connections fail due to signal or coverage issues. Your connection stays fast, and you stay seamlessly connected and productive. | Certified Industrial Durability Built to withstand temperatures from -40 to 65 C and featuring ESD/surge protection for all ports, the Pepwave MAX is designed for worry-free performance everywhere you roam. Add industrial-grade shock/vibration resistance (EN 61373:1999 IEC 61373:1999), a terminal block for reliable power sourcing, and a rugged 10-32 VDC power supply, and you've got a mobile router that can take anything the road can dish out. |
Up to 7 Internet Connections The Pepwave MAX combines as many as seven 3G/4G, WiMAX, LTE, VSAT, Wi-Fi WAN, and other mobile connections to deliver consistently high speeds and 100% uptime. Bond up to four USB modems and add broadband landline connections for blazing data transfer anywhere, anytime. | Cap- and Cost-Aware Routing |
Embedded World-Mode 3G Modems Leave your external GSM and CDMA modems behind. The Pepwave MAX HD2 features integrated world-mode 3G modems for instant connectivity anywhere you go. And because the MAX is easy to configure and shock/vibration resistant, you can give your mechanic a break. | Dual-Radio Wi-Fi Functionality The Pepwave MAX can automatically switch to Wi-Fi networks as they become available, cutting costs and increasing bandwidth. Got bandwidth to spare? Share it seamlessly and securely with the MAX's built-in Wi-Fi access point. |
Military-Grade VPN Encryption The MAX is ideal for public safety and sensitive private communications. Our revolutionary VPN engine allows you to use all available Internet links to load balance and failover your traffic through 256-bit AES encrypted VPN tunnels. Since our VPN engine is designed from the ground up for multiple Internet connections, you can be assured that you will be securely connected wherever you are. | GPS Fleet Tracking The Pepwave Max's built-in GPS fleet tracking lets you keep tabs on fleet vehicles wherever they may be. Easy to interface with external GPS systems, MAX GPS fleet tracking maximizes resources and team coordination while improving safety and productivity. |
Ease of Use Get up and running quickly using the MAX's intuitive user interface. With separate logins for administrators and users, the Pepwave MAX UI offers helpful setup wizards, comprehensive status displays, and complete, easy-to-use control over your mobile connectivity solution. | Centralized Management Track your fleet, keep an eye on mobile resources, and update firmware and profiles from one interface, anywhere and anytime. The Pepwave MAX even features auto-provisioning to keep things running smoothly when you've got better things to do than manage your mobile network. |
