LTE-A
Increased Band Support and Carrier Aggregation
LTE-A features greater location diversity, one modem can cover more regions. LTE-A also supports newer region and carrier specific bands. These are often much faster than the legacy bands that can become oversaturated. For the US market, LTE-A enabled models support band 41 (2500 MHz) and band 26 (850 Mhz) for Sprint and band 12 (700 MHz) for T-Mobile. For the Asia-Pacific markets, LTE-A models also support TD-LTE bands 38 (2600 MHz) and 40 (2300 MHz).
In addition, LTE-A routers can use Signal Carrier Aggregation (SCA) to simultaneously connect multiple signal channels for up to twice your current connection speed.
Coverage Area
While many LTE-A enabled routers offer greater band support, the coverage is still limited to that of a single provider, so you will still lose reception if you hit a dead spot. With SpeedFusion Bandwidth Bonding, however, you can enjoy uninterrupted service as you move around town, connecting to 3G/4G LTE networks from multiple service carriers.
LTE-A Multi-cellular Routers #2
LTE-A Multi-cellular Routers #3
Explore Peplink Products for LTE-A
With LTE-A supported multi-cellular MAX routers, you can combine the additional frequency bands and enhanced speed of LTE-A enabled routers with the greater connection reliability and cellular coverage of SpeedFusion bandwidth bonding for the best cellular connection possible.
Check out all our LTE-A models in the online store!
Difference Between SKUs
