Business with SFC Cover
Make your branch connection unbreakable
Business with SpeedFusion
Be it a single office or thousands of branches, you’ll need a good connection to ensure business runs smoothly.
SpeedFusion Connect
Make sure your VoIP and online services stay stutter free
Enjoy the open air as you work with zero network disruptions
Peplink eSIM Data Plans
Cover your bases with a data plan that never fails
Top up your eSIM data with just a few taps
Monitor Your Network
All of your Peplink devices accessible from the palm of your hand
App UI
Generate Network Reports
Check on the quality and data usage of each WAN connection
App UI
SFC App Section Background
Manage SpeedFusion on our companion app
Peplink App
Bring the easiness of network management to the palm of your hand
UI Image 1
Monitor Your Router
connection status and configure WAN usage
UI Image 2
Connect Your Router
to Peplink Cloud Locations in over 25 cities
UI Image 3
Active SpeedFusion Service
for connectivity protection
UI Image 4
View Reports
on WAN quality and data usage
UI Image 5
Share Access
with friends and family to manage your devices
UI Image 6
Manage Multiple Routers
at the same time
