Peplink ‘s line of products includes features that make your enterprise deployment easier and increase your network reliability and security in several ways. Boost network data rates, reliability, and flexibility while slashing connectivity costs with Peplink SD-WAN technology designed for multi-WAN link load balancing. Use Load Balancing and SpeedFusion bandwidth bonding to deliver superfast VoIP, video streaming, and data using an SD-WAN enabled network.
Branch/Small Office
Small Business
Mid-Size Business
Large Enterprise/Campus
Cloud/VM
Use Cases
Retail
Hospitality
Branch Networking
Retail Connectivity Solution
The Balance 30 Pro can handle all your networking needs. With the PoE activation kit, its four PoE LAN ports can connect and power your payment terminal, IP phones, Wi-Fi hotspots. The Balance 30 Pro has one cellular and two Ethernet connections, ensuring that your network and business will keep running no matter what. Use the Ad Delivery service to deliver advertisements and surverys to your customers before they connect to your Wi-Fi.
Branch Site Setup
In this video Peter from West Networks demonstrates how to use the Balance 30 Pro to deploy branch office connectivity in under 5 minutes.
SD-WAN With Dual Wired Ports and LTE
The Balance 30 Pro supports two wired connections and one LTE with SD-WAN capabilities for traffic steering, load sharing and failover, powering your critical business continuity.
Redundant SIM Slots
Redundant SIM slots with automatic switching for reliable network. You can set the Balance 30 Pro to automatically switch SIM cards when you’re in danger of data overage, or aggregate capacity of multiple SIM data plans.
Add PoE Kit to Enable 4-port PoE Switch
With the PoE activation kit, all LAN ports can support PoE output. That way, you can hook PoE powered devices such as IP Phones and additional Wi-Fi APs. Perfect for Branch Networking.
Built to Last
Balance 30 Pro is supported by InControl, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
InControl makes your network scalable. From any web browser, you could remotely push a wide range of settings to multiple devices in your network
Captive Portal
QoS
Customizable Captive Portal With Ad Delivery
Use InControl to customize the captive portal and apply it to any SSID. With InControl’s scalable architecture, you can apply the SSID to multiple devices in your network using device tags. Use the cloud-based Ad Delivery Service (ADS) to monetize your Hotspot.
QoS : Determine Traffic Priority
QoS enables you to assign different priority levels to different types of traffic. Minimize latency by giving high priority to VoIP traffic. Control data costs by limiting the speed of bandwidth-intensive applications.
Web Admin Demo
