SFC Cover
Supercharge Your Connectivity
SFC Logo
Learn More
Jumpdown Button
Why incorporate SpeedFusion Connect into your connectivity?
Global Coverage
Global Coverage
Leverage the global reach of public clouds to ensure that you get the fastest response time and the most reliable connection.
SpeedFusion Technology
Enjoy Bandwidth Bonding, Smoothing, and Supercharged Connectivity from any compatible router.
Minimal Infrastructure Needed
No need to invest in core hardware, setting up, or even maintenance.
Reduce Network Costs
Optimize your network by combining multiple commodity links to create a high bandwidth tunnel.
Supported Models
Require firmware 8.1.0 or above
Enterprise Routers
Balance | SDX | EPX
Enterprise Routers
Balance Series
SDX Series
EPX Series
Enterprise Mobility
HD | Dome | MBX | PDX
Enterprise Mobility
HD Series
Dome Series
MBX Series
PDX Series
Mobile Routers
BR | Transit | UBR
Mobile Routers
BR Series
Transit Series
UBR Series
Soho Routers
Soho | B One
Soho Routers
Soho Series
B One Series
Others
SFE
Others
SpeedFusion Engine Series
SpeedFusion Connect Usage Plans
Unlimited Plans
SFC-CLD-U-1M
SFC Unlimited Usage
Unlimited Usage / 400 Mbps
1 Month Valid
Learn More
SFC-CLD-U-1Y
SFC Unlimited Usage
1 Year Valid
Learn More
Regular Plans
SFC-CLD-B
SFC Plan B
500GB / 200 Mbps
180 Days Valid
USD 20
SFC-CLD-C
SFC Plan C
1TB / 200 Mbps
365 Days Valid
USD 40
SFC-CLD-D
SFC Plan D
2.5TB / 200 Mbps
365 Days Valid
USD 80
SFC-CLD-E
SFC Plan E
5TB / 200 Mbps
2 Years Valid
USD 159
SFC-CLD-F
SFC Plan F
10TB / 200 Mbps
3 Years Valid
USD 299
SFC-CLD-G
SFC Plan G
20TB / 200 Mbps
3 Years Valid
USD 589
Purchase / Top Up
Peplinks eStore Certified Partners SFC Portal
All pricing applies to US region only, other regions may vary
Please also refer to our SFC Usage Plan & Peplink eSIM Data Plan Terms and Conditions.
Frequently Asked Questions
Q1
What is SpeedFusion Connect (previously known as SpeedFusion Cloud)?
SpeedFusion Connect is Peplink’s infrastructure that provides access to a global network of SpeedFusion endpoints and technology without requiring additional hardware.
Q2
Can I purchase one SpeedFusion Connect plan and leverage it over multiple Peplink devices?
No, each SpeedFusion Connect plan is attached to a single device’s serial number. Each device must have its own plan in order to utilize SpeedFusion Connect.
Q3
How do I activate the SpeedFusion Connect allowance that’s included with my Care plan?
All Care plans now come with SpeedFusion Connect included. This data allowance will automatically begin and end in accordance with your warranty. No activation is required.
Q4
Can I activate SpeedFusion Connect once and link multiple Peplink devices to it?
Yes you can, the SpeedFusion Connect does not count towards your device’s peer limit.
Q5
Does SpeedFusion Connect count towards my SpeedFusion peer limit?
No, it does not.
Q6
My plan has expired but I still have usage left. What happens? Will it rollover?
Any remaining usage from expired plans will not be carried forward.
Q7
Can I track and monitor my SpeedFusion Connect usage?
Yes, keep track of your usage via the dashboards of your router’s WebUI.
Q8
How are SpeedFusion endpoints allocated?
An option to either manually choose your endpoint or automatically be assigned an endpoint is available. Click to learn more here.
Q9
How do I ensure the application that I want to protect uses SpeedFusion Connect?
You can use an outbound policy to ensure that traffic from a specific application goes through SpeedFusion Connect. Define your source traffic as “any” and select your application under “protocol”. Select “enforced” as your algorithm, and finally, select the SpeedFusion Connect as the enforced connection.
Q10
If I purchase multiple plans will the validity of the plans accumulate?
The maximum validity is 3 years. For example, If you buy 2x SFC-CLD-F plans at the same time, which has a 3-year validity per plan, the maximum expiry will still be 3 years.
Q11
I have activated “Auto-Renewal” in eStore. When will my subscription Auto-Renew?
By default, the preset trigger is set at 7 days prior to expiry or 10% data remaining, whichever comes first. Click to learn more here.
Q12
Does utilizing SpeedFusion Connect require special firmware?
Yes, all compatible models are required to have firmware version 8.1.0 or higher to utilize this service.
Still need help?
Submit your question to our Forum here.
