Unbreakable VoIP
Your Phone Connection Never Breaks
Challenges
Relying on one fixed connection for your entire infrastructure is really not optimal by today’s standards, especially if a connection breaks, so does everything around it. Slow speeds, not enough bandwidth, unclear or even broken calls are often experienced by many of the users prior to discovering Peplink.
Even worse, what if there is no fixed line available? What if your rural location can only receive subpar cellular coverage?
VoIP – Great When It Works
VoIP is a double-edged sword. It provides amazing value, but it’s fussy. Just when you need it most, it sputters or drops out completely, leaving staff and customers speechless.
VoIP calls can sound robotic and choppy on low quality networks with high latency and jitter. Not good for your image. Worse, network failures can stop conversations dead, infuriating staff and customers, as well as wasting time and resources.
High quality VoIP needs a high quality network. And that usually comes at a high cost.
At least that’s how it used to be.
SpeedFusion VPN = Unbreakable VoIP
SpeedFusion drives highly available and secure networks with failsafe resiliency – perfect for VoIP. Just use two or more broadband connections. You can even pair it with a cellular connection. No need to break the bank to get unbreakable VoIP.
SpeedFusion VPN provides connection failover between a pair of our devices using a technology we call Unbreakable VPN. If one connection fails, Unbreakable VPN sends traffic over healthy connections without missing a beat. This happens at the packet-level – even when a connection breaks, your conversation continues. No chop. No drop. No irate staff and customers.
Sound complicated? Don’t worry. Our devices are stuffed with powerful, complex features that all just work. Out of the box, you’re only a few clicks away from rock-solid VoIP.
Hosted VoIP That’s More Than Just Talk
If you have only one office and are using a hosted VoIP solution, our load balancing technology can keep your conversations flowing even when one of the connections fails.
Load balance voice and data across multiple connections. Prioritize VoIP across the lowest latency links. Better yet, isolate all VoIP traffic to a single connection to separate voice and data. Peplink QoS lets you do all that and more.
Keep Your Conversations Going
If one connection fails, new VoIP calls will be automatically sent through other healthy connections. For additional connection resilience, simply plug in a cellular USB modem.
So no matter what, you stay connected to your customers, staff and suppliers.
Effortless Scalability With InControl
If you provide customer-premises equipment, you’re probably visiting those sites more than you’d like.
But with InControl, you could be managing thousands of devices, client sites, and even whole regions right from your desk. Or home. Or cafe. Without rolling a single truck or using a single drop of gas.
Peplink’s cloud-based monitoring and reporting tool allows you to remotely monitor site-to-site traffic. Plus, you can securely tunnel into the web admin of each device while keeping nosy clients out. Make configuration changes without rebooting. Schedule firmware upgrades when it’s convenient. All with InControl, our powerful and easy-to-use cloud-based management tool.
Remote Web Admin Access
Scheduled Batch Firmware Upgrades
Cloud VoIP Powered by SpeedFusion
FusionHub is a SpeedFusion-capable virtual appliance that delivers Unbreakable SIP sessions to all your Peplink single-device customers. FusionHub is extremely flexible, and it’ll happily coexist alongside your hosted VoIP PBX in the cloud.
Provide more value-added services and applications over your SpeedFusion Unbreakable connection with FusionHub. It’s super fast, highly resilient, widely compatible (e.g. RDS, ERP) and protected by military-grade encryption. And it installs in a flash.
Balance 20X
  • Cost-effective expandable SD-WAN router
  • Has multiple LAN ports for connecting network devices
  • Adding an extra cellular connection using a USB dongle or expansion module, further increasing reliability.
  • Ideal for medium enterprises or branches
UBR LTE
  • A budget-friendly dual cellular router
  • Capable of Bandwidth Bonding, combining the bandwidth of 2 LTE connections
  • Ideal for areas without access to landlines
BR1 Mini
  • Best value Industrial-Grade Router with multi-WAN inputs
  • Supports Ethernet WAN, Wi-Fi WAN, Hot Failover, WAN Smoothing with Feature Pack
  • Ideal for small, family-owned, or independent businesses.
Case Study. Social Enterprise Pluss
Steve found the solution Pluss needed in Peplink products. The Balance series of high performance enterprise routers and SpeedFusion bonding technology. Pluss now powers its entire WAN infrastructure with simple to install, highly reliable, and cost-effective Peplink gear. This allowed them to aggregate DSL and other commodity connections and replace expensive leased lines.
