cover-image
How-To Handbook
Your How-To Guide to All Peplink-Related Setup
Device Setup
Setting up your device is the first step to building your Peplink network. Learn how to set up specific Peplink devices with these videos.
    Learn how to set up a Balance 20X device such as installing an expandable modem as well as antennas.
    Learn how to set up the MAX Transit Duo such as SIM installation, antenna installation, and how to get access to your web admin page.
    Learn how to set up the BR1 Mini and enable Hot Failover on InControl to create a reliable network.
    Learn how to use Peplink’s online ticketing system, to expedite the whole customer support process.
    Learn how to complete the sales registration for your devices in order to activate your warranty.
    Learn how to update both the cellular module firmware and the device firmware to use Verizon’s C-Band.
    Learn how to activate the MAX BR1 HW3 WAN functionality after purchasing the feature pack.
    Learn how to manually apply a Peplink license key using Web Admin.
    Learn how to activate a 3rd Party eSIM Profile on a Peplink Router.
InControl
InControl is Peplink’s cloud-based device management, monitoring, and reporting platform. Take full control of your network and learn how to effectively use InControl.
Introduction to InControl
Get to know InControl, its features, and its benefits. Learn how to log in to InControl and access the Remote Web Admin page to view the different management tools.
    Learn how to unlock the full potential of your Peplink device, by registering a Peplink ID and logging into InControl.
    Learn how to log in to InControl and access the remote Web Admin page in order to configure your device to your liking.
    Learn how to create a full Peplink ecosystem by adding all your Peplink devices to your organization on InControl.
    Learn how to delegate control of your organization or group to another person on InControl when needed.
    Learn how to set up or modify your SSID and Wi-Fi settings through Web Admin.
    Learn how to use InControl to find your International Mobile Equipment Identity (IMEI), a 15-digit number unique to each Peplink device.
    Learn how to use Web Admin to find your International Mobile Equipment Identity (IMEI), a 15-digit number unique to each Peplink device.
    Learn how to access a Peplink device’s web Graphical User Interface (GUI) from InControl.
    Learn how to add and remove devices to and from a group in InControl.
    Learn how to enable or disable remote assistance on a Peplink device using Web Admin.
    Learn the different ways to acquire a diagnostic report for your Peplink device. This report is extremely useful for assisting Peplink engineers with troubleshooting your device.
Functions of InControl
Learn how to activate and configure different SpeedFusion Cloud functions to match your needs.
    Learn how to use Zero-Touch Configurations on InControl to manage and troubleshoot large-scale or multi-device networks.
    Learn how to configure Peplink’s firewall access rules to secure your network. You now have the choice to block or filter specific devices or traffic.
    Learn how to configure your SIM priority while also controlling data usage.
    Learn what High Availability (HA) mode is and how to set it up. This video will also explain the advantages of using this unique feature offered by Peplink.
    Learn how to configure an InTouch rule for accessing devices behind your Peplink router.
    Learn how to download and upgrade firmware for devices through Web Admin. Also, learn how to manually update the firmware by accessing our website.
    Learn how to update the cellular module firmware on a Peplink device through InControl.
InControl Settings
View key information about your devices and modify settings in InControl.
    Learn how to keep your devices up to date by adjusting your firmware settings.
    Learn how InControl’s email notifications can be modified to suit your organization’s needs.
    Learn how to set up and configure route advertisement protocols for your device and network. This includes setting up OSPF, RIPv2, and BGP protocols.
SpeedFusion
Peplink’s patented SpeedFusion technology powers enterprise VPNs that tap into the bandwidth of links connected anywhere on your corporate or institutional WAN. Dive deeper into SpeedFusion and the accompanying technologies with the following videos.
    Learn how to set outbound policies and steer your traffic within a SpeedFusion tunnel to protect your data and network.
    Learn how to set up a SpeedFusion VPN. This is a bonded VPN technology that allows you to aggregate multiple internet connections together.
    Learn how to set up SpeedFusion features such as Hot Failover and Bandwidth Bonding to your network. Also, understand how to evaluate the SF bonding speed.
Troubleshooting
Use these tutorial videos to help you troubleshoot any problems you encounter.
    Learn how to set up and use SpeedFusion as well as some basic troubleshooting, such as conducting our very own VPN test.
    Learn how to conduct a WAN analysis. WAN Analysis is useful for determining the speed at which Peplink products are functioning at different sites.
    Learn how to configure a simple PepVPN or SpeedFusion VPN tunnel with Hot Failover enabled.
    Learn how to configure a simple PepVPN or SpeedFusion VPN tunnel with Smoothing enabled.
    Learn how to configure a simple PepVPN or SpeedFusion VPN tunnel with Bandwidth Bonding enabled.
    Learn how to create sub-tunnels on a single SpeedFusion VPN connection.
    Learn how to set up and configure SpeedFusion on InControl. This includes configuring the profile settings and some advanced link settings.
    Learn how to access in-depth signal details for cellular routers. This can be highly beneficial for assisting with troubleshooting a device or network.
    Learn how to conduct basic troubleshooting of your network through web admin.
VPN
Keep your network secure with a VPN. SpeedFusion VPN is ideal for establishing a secure tunnel over any WAN link and can be considered the world’s easiest site-to-site VPN. Learn more about Peplink’s available VPN server connections and our foundation VPN engine.
    Learn how to set up L2TP (Layer 2 Tunneling Protocol) with IPsec (Internet Protocol Security) offers more secure and flexible communications over your network.
    Learn how to configure your PPTP VPN server connections, one of Peplink’s available VPN server connections.
    Learn how to configure your L2TP VPN server connections with IPsec, one of Peplink’s available VPN server connections.
    Learn how to configure your Open VPN server connections with IPsec, one of Peplink’s available VPN server connections.
    Learn about PepVPN, Peplink’s site-to-site VPN connection. Also, learn about how to configure it on Firmware 8.1x.
Wireless Settings
Peplink’s mission is to make unbreakable connectivity always work. Learn the best Wi-Fi setups and more with these tutorials.
    Learn how to set up a WDS and Mesh network, allowing your wireless network to be accessible throughout a larger area without using an ethernet cable.
    Learn how to set up wireless settings for optimal performance and flexibility.
    Learn the process of adding secondary wireless access points to your Peplink router.
    Learn how to configure Peplink wireless mesh on a Peplink External Access Point.
    Learn what Wi-Fi really means and how to connect to an external Wi-Fi source using Wi-Fi as Wan.
