Rethinking Connectivity
SpeedFusion Connect
SpeedFusion Connect improves connection reliability with global endpoints & on-demand 5G/LTE cellular data
The Global Infrastructure behind SFC
How It Works
To integrate SpeedFusion features into your network, you’d normally need two different end points to complete the setup, typically two separate devices.
We understand that this may not be feasible for all of our users. That’s why we’re hosting nodes in 28 locations around the world to act as a second end point for our users to connect to. This means that as long as you have one of our routers in your network, you’ll be able to access all of SpeedFusion’s features with an Speedfusion Connect subscription.
Global Support
Global Support
28 Cities and 19 Countries
Bandwidth Bonding
Bandwidth Bonding
Combine multiple connections into a single faster connection
Hot Failover
Hot Failover
Instantly fallback to a backup connection for zero connection drops
WAN Smoothing
WAN Smoothing
Send the same data through multiple connections so no data gets lost
Protect your Applications and Connections
SpeedFusion Connect
Guard your network by making it unbreakable with SpeedFusion Connect.
Enhance your network with SpeedFusion and protect your connection. Let stutters be a thing of the past.
  • Reliable high speed Internet
  • No more disconnects for VoIPs
  • No network congestions while you access business apps (e.g. Zoom, Microsoft 365, Google Workplace)
Our on-demand data plan
eSIM Data Plans
Stay connected wherever you are with Peplink’s on-demand cellular data plan.
No contracts, no monthly fees. Pay for what you need, and instantly enjoy an unthrottled connection.
Find out which countries we support here.
Get in touch with your devices anytime, anywhere
InTouch
Control all your network devices through InTouch.
As long as a Peplink device is integrated in your network, you’ll be able to remotely access the rest of your network devices with just a few clicks.
  • Remotely manage all your devices through a single interface
  • Easy to activate and easy to use
  • Comes included with all our care plans
Learn More
Build your own private cloud node
SpeedFusion Relay
SpeedFusion Alliance
Join the SpeedFusion Alliance and offer your cloud nodes to the public. We are constantly working with our partners to build new SpeedFusion Cloud Nodes around the world for all our users. If you’re interested in joining us, let us know by emailing us at [email protected].
Instead of using our global SFC endpoints, you can instead host your own private cloud node using a second Peplink router. For those concerned about security, this ensures that only users you trust can connect to your network.
Private Cloud Node
SFC App Section Background
Manage SFC on our companion app
SpeedFusion App
Bring the easiness of network management to the palm of your hand
UI Image 1
Monitor Your Router
connection status and configure WAN usage
UI Image 2
Connect Your Router
to Peplink Cloud Locations in over 25 cities
UI Image 3
Active SFC Service
for connectivity protection
UI Image 4
View Reports
on WAN quality and data usage
UI Image 5
Share Access
with friends and family to manage your devices
UI Image 6
Manage Multiple Routers
at the same time
