SD Switch
Comparison Table
  • SD Switch Rugged, 8-PortSD Switch Rugged, 16-PortSD Switch Rugged, 24-Port
    LAN Interface8x 802.3at (PoE+) GE Ports@,
    2x SFP Ports
    8x 802.3at (PoE+) GE Ports@ ,
    8x GE Ports,
    2x SFP Ports
    24x 802.3at (PoE+) GE Ports,
    2x SFP+ Ports
    VLAN GroupsYesYesYes
    Fiber Module2x 1 Gbps2x 1 Gbps2x 10 Gbps
    Switch Capacity20 Gbps36 Gbps88 Gbps
    Max. Packet Forwarding Rate14.9 Mpps26.8 Mpps66 Mpps
    MAC Address Table8,0008,00032,000
    Inter-VLAN RoutingNoNoYes
    AC AdaptorAC Input 100V-240V
    DC Output 54V#
    AC Input 100V-240V
    DC Output 54V#
    AC Input 100V-240V
    DC Output 54V%
    Power InputDC Power DIN 2x 54V
    Terminal Block: 12V – 56V DC
    DC Power DIN 2x 54V
    DC Power DIN 2x 54V
    Terminal Block: 12V – 54V DC
    Power Consumption20W System,
    90W PoE+ Power Budget
    (supports up to 240W#)
    20W System,
    50W System,
    120W PoE+ Power Budget
    (supports up to 250W%)
    Dimensions (L x W x H)8.2 x 6.3 x 1.7 inches
    210 x 160 x 43 mm
    7.5 x 9.0 x 1.5 inches
    190 x 226 x 35 mm
    10.5 x 19.1 x 1.7 inches
    265 x 485 x 45mm
    Weight2.2 pounds
    1.0 kg
    4.4 pounds
    2.0 kg
    11.3 pounds
    5.14 kg
    Operating Temperature-40° – 149°F
    -40° – 65°C
    -40° – 149°F
    -40° – 65°C
    -40° – 149°F
    -40° – 65°C
    Humidity15% – 95% (non-condensing)15% – 95% (non-condensing)15% – 95% (non-condensing)
    CertificationFCC, CE, RoHS, E-Mark, IC
    EN 61373:1999 IEC 61373:1999 : Shock and Vibration Resistance
    EN 50155: Railway Applications
    EN 61000: Electromagnetic Compatibility
    EN 45545-2: Fire Protection on Railway Vehicles
    FCC, CE, RoHS, IC*
    EN 61000: Electromagnetic Compatibility*
    Warranty1-Year Limited Warranty1-Year Limited Warranty1-Year Limited Warranty
    Package ContentSD Switch 8-Port Rugged,
    1x PSU 120W,
    1x Power Cord (ACW-614),
    Ear Mounts/DIN Rail Mount kit (ACW-DIN-PSW8),
    4pin Terminal Block Connector (Power supply),
    Rubber Foot Pad set
    Switch 16 Port Rugged,
    1x PSU 120W,
    1 Pair of Mounting Brackets (ACW-756),
    Rubber Foot Pad set
    SD Switch 24-Port Rugged ,
    1x PSU 180W (ACW-630),
    Screw set for rack mounting,
    2pin Terminal Block Connector,
    Rubber Foot Pad set
    # The bundled PSU provides 90W of PoE power budget. If you require 240W of power budget, please add 180W PSU (ACW-630) to your device.
    % The bundled PSU provides 120W of PoE power budget. If you require 250W of power budget, please add 180W PSU (ACW-630) to your device.
    @ PoE output requires a minimum of 48V power input.
    * Pending certification
  • SD Switch, 24-PortSD Switch, 48-Port
    LAN Interface24x 802.3at (PoE+) GE Ports,
    2x SFP+ Ports
    48x 802.3at (PoE+) GE Ports,
    4x SFP+ Ports
    VLAN GroupsYesYes
    Fiber Module2x 10 Gbps4x 10 Gbps
    Switch Capacity88 Gbps176 Gbps
    Max. Packet Forwarding Rate66 Mpps131 Mpps
    MAC Address Table32,00032,000
    Inter-VLAN RoutingYesYes
    Power Input2x 100V – 240V AC Input,
    With Power Redundancy
    Integrated Power Source850W: 3x Redundant PSU3x Redundant PSU
    Power Consumption50W System,
    850W PoE+ Power Budget
    100W System,
    800W PoE+ Power Budget
    Dimensions (L x W x H)19.1 x 15.7 x 1.7 inches
    485 x 400 x 45 mm
    485 x 400 x 45 mm
    Weight13.7 pounds
    6.2 kg
    15.4 pounds
    7.0 kg
    Operating Temperature32° – 104°F
    0° – 40°C
    32° – 104°F
    0° – 40°C
    CertificationFCC, CE, RoHS, IC
    FCC, CE, RoHS, IC
    Package ContentSD Switch 24-Port Enterprise,
    2x Power Cord (ACW-614),
    2x L-Mount for switch back side,
    Rubber Foot Pad set
    SD Switch 48-Port Enterprise,
    Rubber Foot Pad set
