Pepwave Surf SOHO Specifications
 Designed for Small Business and Power Users
surf soho specifications
WAN Interface1x 100/1000M Ethernet Port
1x USB 2.0 Interface
Wi-Fi as WAN
LAN Interface4x 100/1000M Ethernet Ports
Simultaneous Dual-Band 11ac Wi-Fi AP
Wi-Fi AP Operating Frequency2412 − 2472MHz and 5180 − 5825MHz
Wi-Fi Data Rates3x3 MIMO, 2.4GHz: 450Mbps or 5GHz: 1300Mbps
Wi-Fi Antenna3x External Wi-Fi Antenna
Recommended Users1-25
Router Throughput120Mbps
Number of Simultaneous L2TP/PPTP VPN Users3
Number of PepVPN Peers2 (5 with upgrade license)
PepVPN Throughput (256-bit AES)20Mbps
PepVPN Throughput (No Encryption)40Mbps
Power InputDC Jack: 10V − 24VDC
AC Adapter: AC Input 100V − 240V, DC Output 12V, 3A
Power Consumption26W (max) with USB WAN
22W (max) without USB WAN
Dimension9.17 x 5.6 x 1.18 inches
233 x 142.2 x 30 mm
Weight0.86 pounds
388 grams
Humidity15% − 95% (non-condensing)
CertificationsFCC, CE, RoHS
Supporting
250+ USB Modems from Worldwide Carriers
Warranty1-Year Limited Warranty
ssoho-dimensions
Ordering Info
Product CodeDescription
SUS-SOHO-TProfessional-grade Wi-Fi router designed for home office, small business, and power users. Supports one Ethernet, one USB 4G LTE/3G WAN, and Wi-Fi as WAN for failover. Includes three SMA dual-band antennas.
Feature Add-on
Product CodeFeature PackDescription
PVN-LC-05PepVPN License Key for Surf SOHOEnables up to 5 PepVPN connections
Technical Specifications
