MFA 200
Unbreakable Connectivity with Content Caching
The MFA 200 comes equipped with MediaFast, our supercharged content caching solution. Designed with education & entertainment in mind, it downloads and accelerates video, iTunes, IOS updates, app downloads, and other content for uninterrupted learning and fun anytime. The MediaFast can prefetch content during off-peak hours, saving connectivity costs and reducing network burden during busy times.
200Mbps Content Cashing Router MediaFast 200 #2
Works With
  • iTunes
  • iOS Updates
  • TED.com
200Mbps Content Cashing Router MediaFast 200 #3
Hassle Free Solution for Branch Connectivity
  • Infinite playback of cached content. Save money and eliminate network congestion.
  • More effective use of time in class. Focus on learning and teaching, not loading.
  • Central Management Platforms, your one stop management and monitor station.
Stable Connectivity
Peplink routers enable you to add bandwidth, wired or wireless, anytime and load balance multiple Internet links. Automatic failover allows you to maintain an unbreakable connection. You can download media-rich course materials effortlessly with the MediaFast.
200Mbps Content Cashing Router MediaFast 200 #5
Prefetch Off-Peak Downloads
Schedule one-time or recurring content downloads during off-peak hours, and then playback downloaded content anytime. Need HD video and other content in places with spotty or congested Internet connections? Download whenever and wherever the connection is best. Then pack up and take the MediaFast anywhere you need seamless content delivery
200Mbps Content Cashing Router MediaFast 200 #6
Reporting.
Deep Insights.
On-Demand.
Check bandwidth usage and savings. Track popular URLs and file types. Monitor client IP addresses, find your heaviest users, and more, all from a single intuitive interface.
200Mbps Content Cashing Router MediaFast 200 #7
Cache.
Download x1.
Playback x∞.
Cache iTunes/iTunes U and other content automatically by domain and file type. With MediaFast, you can download once and play back over and over again, cutting loading time, bandwidth usage and cost. Keep content as long as you like or purge it automatically by file type and age.
200Mbps Content Cashing Router MediaFast 200 #8
Complete Solution & Centralized Management
MFA 200  is supported by InControl 2, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
  •  Branch Office/Hotspot
    ModelMediaFast 200
    Product CodeMFA-200-W
    CategoryWired Only
    Ethernet WAN Ports1/2 &
    Embedded 4G LTENo
    Wi-Fi InterfaceSimultaneous Dual-Band 802.11a/b/g/n AP
    USB 4G LTE/3G WAN [1]1
    Disk Drive120GB SSD
    Cache Throughput [2]150Mbps
    Router Throughput [3]80Mbps
    Ethernet LAN Ports8 (GbE)
    802.3at PoE Output +
    Core Functionality
    Load BalancingNo ^
    Video CachingYes
    Content CachingYes
    InControl Cloud ManagementYes
    Drop-In ModeYes
    GPS Fleet ManagementNo
    AP Controller
    Manage Pepwave AP SeriesYes
    Maximum Number of AP Supported10/50 #
    Manage Remote AP & Multiple Config ProfilesNo °
    VPN Functionality
    PepVPNYes
    SpeedFusion Hot FailoverNo ^
    SpeedFusion Bandwidth BondingNo ^
    Number of PepVPN/SpeedFusion Peers2
    PepVPN/SpeedFusion Throughput
    (No Encryption)
    150Mbps
    (256-bit AES)
    80Mbps
    Advanced QoS Functionality
    Bandwidth Usage MonitorYes
    QoS for VoIP and E-CommerceYes
    User Groups Bandwidth ControlYes
    Web BlockingYes
    Hardware
    Operating Temperature32° – 104°F
    0° – 40°C
    Power Consumption38W
    1U Rack-mountNo
    LAN BypassNo
    Router Throughput and PepVPN/SpeedFusion Throughput is based on Ethernet frame sizes of 1280 or 1518 bytes. Actual performance can vary across different networking environments. Figures apply to the latest hardware revision. The throughput result is tested with DHCP/Static IP WAN.
    WANWAN Support for PPPoE
    Static IP
    DHCP WAN Link Health Check
    Bandwidth Allowance Monitor
    USB 4G LTE/3G Modem Support
    Support for Dynamic DNS
    Services IPv6 Support
    Extended DHCP Options
    DHCP Reservation
    DNS Proxy for LAN Clients
    DNSBuilt-in Authoritative DNS
    Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records
    QoSUser Groups
    Individual Bandwidth Limit
    Application Prioritization
    By User Groups
    SIP, HTTPS, VPN QoS
    Custom Application QoS
    Content CachingVideo Caching
    iTunes
    iTunes U
    TED.com
    Content Caching
    HTML
    JavaScript
    Flash Applications
    AP ControllerSupport for Pepwave AP Series
    Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi usage statistics
    Command Line Interface
    Router Utility Mobile App
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    Complete VPN SolutionSpeedFusion VPN/ SpeedFusion
    Site-to-Site VPN
    Bandwidth Aggregation
    Intelligent Failover
    256-bit AES Encryption
    Pre-shared Key Authentication
    Dynamic Routing
    PPTP VPN Server
    RADIUS, LDAP Authentication
    Security Stateful Firewall
    DoS Prevention
    Web Filtering Blacklist
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
  • Product CodeDescription
    MFA-200-LC-SFSpeedFusion Bonding License Key for MediaFast 200
    ACW-609Includes 1x 48V Power Supply
    Enables 4x 802.3at PoE Output Ports (PoE License automatically applied after kit purchase)
  • Product CodeModelDescription
    MFA-200-WMediaFast 200Caching Router MFA 200 for Education Institution and Branch Office
