MAX Transit
Built for Transportation Deployments
With a compact form factor, simultaneous dual-band 11ac Wi-Fi, and embedded cellular modem, the MAX Transit is ready to deliver fast, reliable Wi-Fi hotspots to your passengers.
400Mbps 4G LTE Router for Public Transportation MAX Transit #10
Use Cases
Shock and vibration resistance
(EN 61373:2010)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The MAX Transit supports band 14, providing additional coverage as the situation demands.
Simultaneous
Dual-Band 11ac Wi-Fi
Reduce Wi-Fi congestion and interference. Simultaneous dual-band Wi-Fi gives you two independent networks that also work together, maximizing the throughput that your passengers can enjoy.
Compatible With:
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #10
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #3
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #5
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #8
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #4
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #9
Compatible on all major carriers. Certified with Verizon* and T-Mobile.
*Not applicable to 5G SKU.
Install it Anywhere
With DIN rail mounts and mounting ears that can be installed from many angles, the MAX Transit is ready to fit into just about any space you have available.
400Mbps 4G LTE Router for Public Transportation MAX Transit #5
Captive Portal
Fleet Tracking
Advertising Services
Wi-Fi Mesh
400Mbps 4G LTE Router for Public Transportation MAX Transit #7
Integrated Captive Portal with Social Wi-Fi
The MAX Transit comes with a customizable captive portal what allows passengers to login with Facebook. As they login, you can use InControl 2 to see insightful reports on user demographics.
Learn More
400Mbps 4G LTE Router for Public Transportation MAX Transit #8
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Learn More
400Mbps 4G LTE Router for Public Transportation MAX Transit #9
External Captive Portal for Advertising Servers
The MAX Transit also supports external captive portals, enabling you to connect to an advertising server. That way, your Wi-Fi hotspots can become a source of revenue.
Learn More
Wi-Fi Mesh Support
Along with an AP Controller, this feature allows for a mesh extension to your network, which can expand network coverage and minimize dead zones.
Learn More
    SoftwarePepwave MAX Firmware
    WAN Link Health Check
    Bandwidth Allowance Monitor
    IPv6 Support
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    -Weighted Balance
    -Priority
    -Overflow
    -Persistence
    -Least Used
    -Lowest Latency
    -Enforced
    -Fastest Response Time
    SpeedFusion
    – Site-to-Site VPN
    – SpeedFusion Hot Failover^
    – SpeedFusion WAN Smoothing^
    – SpeedFusion Bandwidth Bonding ^
    – 256-bit AES Encryption
    – Pre-shared Key Authentication
    – Dynamic Routing
    – PPTP VPN Server
    – RADIUS, LDAP Authentication
    IPsec VPN (Network-to-Network)@
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    Security128-bit WEP
    WPA & WPA 2
    Stateful Firewall
    DoS Prevention
    Web Blocking
    Advanced QoSIndividual Bandwidth Limit
    Application Prioritization
    -SIP, HTTPS, VPN QoS
    -Custom Application QoS
    Wi-Fi Usage Statistics
    Device Location Map
    Support RADIUS Authentication
    Social Wi-Fi Hotspot support
    External Captive Portal support
    Certifications-FCC, CE, RoHS, IC
    -E-Mark*
    -EN 61373:1999 IEC 61373:1999 Shock and Vibration Resistance
    -EN 50155 Railway Applications – Electronic Equipment used on Rolling Stock
    -EN 61000 Electromagnetic Compatibility
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    ^ Feature is available as an add-on license.
    * IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
    @ X.509 is only supported on MAX-TST-DUO.
  • Product CodeEmbedded
    Modem(s)
    RegionsLTE Bands3G Bands
    MAX-TST-GLTE-G-T-PRM1x CAT-18Global / FirstNetB1, B3, B25(B2), B66(B4), B26(B5/B18/B19),
    B7, B8, B12(17), B13,B14 , B20, B28, B29,
    B30, B32, B71, B38, B39, B40, B41, B42,
    B43, B46, B48
    B1, B2, B4, B5(B19), B8
    MAX-TST-LTEA-R-T1x CAT-12America / FirstNetB1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B14, B18,
    B19, B20, B26, B29, B30, B32, B41, B42, B43, B46,
    B48, B66
    HSPA+: B1, B2, B4, B5, B6, B8, B9, B19
    MAX-TST-LTEA-K-T1x CAT-12GlobalB1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B18, B19,
    B20, B26, B28, B29, B30, B32, B41, B42, B43, B46,
    B48, B66
    MAX-TST-LTEA-W-T1x CAT-6WorldwideB1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25,
    B26, B29, B30, B41
    WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8
    MAX-TST-LTEA-P-T1x CAT-6Asia PacificB1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39,
    B40, B41
    WCDMA/HSPA+/DC-HSPA+: B1, B5, B8, B9, B19
    UMTS: B6 TD-SCDMA: B39
    MAX-TST-E-T1x CAT-4Europe / InternationalB1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD),
    B41 (TDD)
    * China & HK TD LTE are excluded.
  • Product CodeCarrierModem5G Bands4G Bands
    MAX-TST-5GD-T-PRMGlobal/5G15G (NSA) Sub 6Ghz:
    n1, n2, n3, n5, n7, n8, n12,
    n20, n28, n38, n41, n66,
    n71, n77, n78, n79
    B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17,
    B18, B19, B20, B25, B26, B28, B29, B30, B32,
    B34, B38, B39, B40, B41, B42, B46, B48, B66, B71
    Product Code
    Description
    PRM-MAX-TST-GLTE-G-1Y
    1-Year PrimeCare for MAX Transit LTEA (CAT-18)
    PRM-MAX-TST-GLTE-G-2Y
    2-Year PrimeCare for MAX Transit LTEA (CAT-18)
    PRM-MAX-TST-GLTE-G-4Y
    4-Year PrimeCare for MAX Transit LTEA (CAT-18)
    PRM-MAX-TST-5G-1Y
    1-Year PrimeCare for MAX Transit 5G
    PRM-MAX-TST-5G-2Y
    2-Year PrimeCare for MAX Transit 5G
    PRM-MAX-TST-5G-4Y
    4-Year PrimeCare for MAX Transit 5G
    ACW-DIN-TST
    DIN Rail mount kit
    ANT-MB-42G-S-W-6
    7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White)
    ANT-MB-42G-S-B-6
    7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black)
    ANT-MB-22G-S-W-6
    5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White)
    ANT-MB-22G-S-B-6
    5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black)
    PSC-210
    1-Year SmartCare for MAX Transit LTEA
    PSC-410
    3-Year SmartCare for MAX Transit LTEA
    SVL-424
    1-Year EssentialCare for MAX Transit LTEA
    SVL-525
    2-Year EssentialCare for MAX Transit LTEA
    FIPS-LC-TST
    FIPS License for Transit
    PVN-LC-10
    Up to 10 SpeedFusion VPN/ SpeedFusion Peers License Key for Selected Models
    MAX-HD-020-SPF
    Up to 20 SpeedFusion Bonding License Key for MAX Series
  • MAX Transit
    • MAX Transit
    • 12V2A Power Supply (ACW-601)
    • 2x 5dBi Wi-Fi Antennas (ACW-341)
    • 1x GPS Active Antenna (ACW-232)
    • 2x 2dBi 4G LTE Antennas (ACW-234)
    • 1 Pair of Mounting Brackets (ACW-724)
    • 6pin Terminal Block Connector
    MAX Transit (CAT-18)
    • MAX Transit (CAT-18)
    • 4x 2dBi 4G LTE Antennas (ACW-234)
    MAX Transit 5G
    • MAX Transit 5G
    • 12V2A Power Supply (ACW-601),
    • 2x Wi-Fi Dual Band Antenna (ACW-341)
    • 1x GPS Antenna (ACW-232)
    • 4x LTE/5G Antennas (ACW-235)
