MAX BR1 MK2
MAX BR1 MK2
This product is out of stock.
Recommended Alternatives
MAX BR1 MK2
Automatic Failover 4G LTE Mobile Router
The MAX BR1 MK2 offers redundant SIM slots with automatic switching, DC or terminal block power capability, advanced GPS fleet tracking, and remote management, all packed into a durable metal enclosure. It is also Verizon certified.
Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #2
Redundant SIM Slots for Multiple Carriers
Redundant SIM slots with automatic switching for reliable network. You can also set the MAX BR1 mobile router to automatically switch SIM cards when you’re in danger of exceeding a data cap. It also allows you travel across borders without changing SIM cards manually.
Use Cases
Public Safety
Passenger Wi-Fi
Landline Replacement
Topology
Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #4
  1. SpeedFusion delivers unbreakable connectivity using two redundant 4G LTE connections from different carriers.
  2. In case of a WAN failure, SpeedFusion instantly switches traffic to another connection.
Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #11
  1. Setting up a customizable portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS or LDAP servers.
Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #12
  1. InControl 2 provides complete cloud-based device management, monitoring, and reporting and let you check vehicle speed, view cellular coverage, and play back route histories in real-time.
Certified Toughness
In addition to the rugged metal enclosure, the MAX BR1 MK2 mobile router HAS certifications for
Shock and vibration resistance
(EN 61373:1999, IEC 61373:1999)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #6
Terminal Block for Secure Power Supply
The MAX BR1 is equipped with a terminal block for secure power installation in vehicles and other locations.
There is More
We specialize in making complicated technologies simple.  Achieve what others cannot with the following.
Fleet Tracking
Captive Portal
Hot Failover
Compact, Rugged 4G LTE Mobile Router MAX BR1 Slim #7
Fleet Tracking and Management
Track and manage your fleet from anywhere. With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device.
Compact, Rugged 4G LTE Mobile Router MAX BR1 Slim #8
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
Setup a Social Wi-Fi Hotspot to receive valuable demographic data from your users.
Compact, Rugged 4G LTE Mobile Router MAX BR1 Slim #9
SpeedFusion Hot Failover
In case of a WAN failure, SpeedFusion technology powers the MAX BR1 Slim for instant failover, giving you reliable internet connectivity and resources access to datacenter.
#powerofpeplink
    SoftwarePepwave MAX Firmware
    WAN Link Health Check
    Bandwidth Allowance Monitor
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    SecurityStateful Firewall
    DoS Prevention
    Web Blocking
    Complete VPN SolutionSpeedFusion VPN/SpeedFusion
    -Hot Failover
    -Site-to-Site VPN
    -256-bit AES Encryption
    -Dynamic Routing
    -X.509 Certificate Support *
    Application Prioritization
    -SIP, HTTPS, VPN QoS
    -Custom Application QoS
    Device Location Map
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    Captive Portal SupportSupport for Wired and Wireless LAN clients
    Support RADIUS Authentication
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    *Feature is available as an upgrade.
    ^ IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
    Product Code
    Description
     MAX-BR1-ADV
     Advanced Feature Package includes a software license key for Advanced Car-Fi Roaming and SpeedFusion/IPSec X.509 Certification Support
    MAX-LC-DIM
    Drop-in Mode for MAX BR1 Series
    PSC-215
    1-Year SmartCare for MAX BR1 MK2 LTEA
    PSC-415
    3-Year SmartCare for MAX BR1 MK2 LTEA
    SVL-430
    1-Year EssentialCare for MAX BR1 MK2 LTEA
    SVL-690
    2-Year EssentialCare for MAX BR1 MK2 LTEA
    ICS-012
    1-Year InControl Subscription
    ICS-024
    2-Year InControl Subscription
    PVN-LC-05
       Enables up to 5 SpeedFusion VPN/SpeedFusion peers
    ANT-MB-22G-S-W-6
    5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White)
    ANT-MB-22G-S-B-6
    5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black)
  • Product CodeRegion | CarrierEmbedded Modem 4G Bands3G Bands
    MAX-BR1-MK2-LTEA-W-TWorldwide1FDD LTE:
    B1, B2, B3, B4, B5, B7, B8, B12, B13, B20, B25, B26, B29, B30, B41
    WCDMA/HSPA+/DC-HSPA+:
    B1, B2, B3, B4, B5, B8
    MAX-BR1-MK2-LTEA-P-TAsia Pacific1B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
    B1, B5, B6, B8, B9, B19
    TD-SCDMA: B39
    • MAX BR1 MK2
    • 12V2A Power Supply (ACW-601)
    • 2x Wi-Fi Dual Band Antenna (ACW-341)
    • 1x GPS Antenna (ACW-232)
    • 2x LTE Antennas (ACW-815)
    • 4pin Terminal Block Connector
