MAX 700
Quad USB Rugged Mobile Router
The MAX 700 supports quad USB modems and SpeedFusion for fast, reliable connectivity anywhere, plus it includes a built-in 4-port GE switch to reduce clutter in your mobile deployments.
Quad USB Rugged Mobile Router MAX 700 #2
Certified Toughness
In addition to rugged metal enclosure, the MAX 700 is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
RF Port Lightning Immunity
(ITU-T K.20 (+/- 1.5 kV))
Electromagnetic Compatibility
(EN 61000)
Unparalleled Modem Compatibility
Supports 250+ USB cellular modems from more than 100 carriers. Odds are, you can plug in and start surfing instantly. But if not, just connect your modem and turn on Remote Assistance – our engineers will get right to work on adding support for your modem.
Terminal Block for Secure Power Supply
MAX 700 with MediaFast is equipped with a terminal block for secure installation in vehicles and other locations.
Built-in 4-Port GE Switch
The MAX 700 includes a built-in 4-port GE LAN switch, reducing clutter and the need for extra equipment.
Quad USB Rugged Mobile Router MAX 700 #5
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With Social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
  • ModelMAX on the GO
    MAX 700
    Product CodeOTG-U4GN2-R
    Ethernet WAN Ports1 (FE)2 (GE)
    Ethernet LAN Ports1 (FE)4 (GE)
    USB WAN Modem Port44
    Wi-Fi WAN [1]Yes * Yes
    Wi-Fi AP [1]YesYes
    Wi-Fi Standard802.11a/n or /b/g/n
    150Mbps
    802.11ac/a/b/g/n 866Mbps
    802.11a/b/g/n 300Mbps
    Transmit Power (2.4GHz)20dBm
    24dBm
    Transmit Power (5GHz)20dBm22dBm
    Simultaneous Dual-Band-Yes
    Recommended Users [2]25150
    Router Throughput [3]100Mbps400Mbps
    Core Functionality
    Drop-in Mode
    High AvailabilityYes
    WAN as LANYes
    Web BlockingYesYes
    Web Filtering BlacklistsLiteLite
    VPN Functionality
    PepVPN/SpeedFusion Hot FailoverYesYes
    SpeedFusion WAN SmoothingYes #Yes
    SpeedFusion Bandwidth BondingYes
    Number of PepVPN SpeedFusion Peers22/20 +
    PepVPN/SpeedFusion Throughput (No Encryption) 40Mbps100Mbps
    PepVPN/SpeedFusion Throughput (256-bit AES)
    20Mbps60Mbps
    Central Management
    InControl Cloud ManagementYesYes
    GPS Fleet Management--
    AP Controller Functionality
    Manage Pepwave AP SeriesYes
    Maximum Number of AP Supported 30
    Hardware Overview
    EnclosureLow-Profile, All-Purpose
    Indoor Metal
    PoE Output- Up to four 802.3af PoE Outputs^
    Terminal Block Power Connector for
    Mobile/Vehicular Deployment
    Yes
    Dimensions
    (Height x Width x Depth)
    1.2 x 4.3 x 4.3 inches
    30 x 110 x 110 mm
    1.6 x 10.2 x 5.7 inches
    39.5 x 260 x 143 mm
    Weight0.43 pounds
    195 grams
    2.65 pounds
    1.2 kg
    Operational
    AC AdapterAC Input 100V-240V
    DC Output 12V, 2A
    AC Input 100V – 240V
    DC Output 12V, 3A
    Power InputDC 12V – 48V 2ADC 12V – 48V DC, 3A
    Terminal BlockDC 12V – 48V DC, 3A
    Power Consumption9W (without modems)
    20W (max.)
    28W (max.)
    Operating Temperature-14° – 149°F
    -10° – 65°C
    -40° – 149°F
    -40° – 65°C
    Certifications
    FCC, CE, RoHSYesYes
    Shock and Vibration Resistance
    Yes
    Warranty1-Year Limited Warranty
    [1] The frequency range for 802.11b/g/n Wi-Fi and 802.11ac/a/n Wi-Fi are 2412−2472 MHz and 5180−5825 MHz respectively.
    [2] Recommendation for sizing purposes only. No software restrictions applied.
    [3] Router Throughput is valid only for currently shipping devices running Firmware 7.0.1 or later. Router Throughput is based on Ethernet frame sizes of 1280 or 1518 bytes. Actual performance can vary across different networking environments.
    * The MAX On-The-Go supports only one of 802.11b/g/n and 802.11a/n Wi-Fi at a time.
    # Feature is available only on MAX-OTG-U4-SF.
    + The MAX 700 comes with 2 PepVPN/SpeedFusion peers by default. With an optional add-on, it supports up to 20 peers.
    ^ Optional PoE Activation Kit is required to activate PoE Output.
  • SoftwarePepwave MAX Firmware
    WAN Link Health Check
    Bandwidth Allowance Monitor
    USB 3G/4G LTE Modem Support
    IPv6 Support
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    Weighted
    Enforced
    Persistence
    Priority
    Overflow
    Least Used
    Lowest Latency
    Fastest Response Time
    Complete VPN SolutionPepVPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding
    Site-to-Site VPN
    Bandwidth Aggregation
    Hot Failover
    256-bit AES Encryption
    Pre-shared Key Authentication
    Dynamic Routing
    X.509 Certificate Support
    PPTP VPN Server
    RADIUS, LDAP Authentication
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    VRRP HA support
    SecurityStateful Firewall
    DoS Prevention
    Web Blocking
    Advanced QoSUser Groups
    Bandwidth Reservation
    Individual Bandwidth Limit
    Application Prioritization
    By User Groups
    SIP, HTTPS, VPN QoS
    Custom Application QoS
    Wi-Fi Usage Statistics
    Support RADIUS Authentication
    Command Line Interface
    Email Notification
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
  • Product Code CarrierDescription
    MAS-GN2-RWorldwide Quad-USB cellular router. Supports PepVPN, SpeedFusion Bandwidth Bonding and quad-WAN load balancing & failover. Supports 250+ USB 3G / 4G LTE modems from mobile carriers including Verizon, AT&T, Sprint, and worldwide carrier.
