Industrial Wi-Fi Solutions
Pepwave Industrial Wi-Fi solutions
Peplink has a large selection of Wi-Fi products built for industrial deployments. Weatherproof IP55 and IP67 access points enable you to set up wireless Internet access in the harshest environments. Our outdoor access points can be powered via 802.3at PoE, reducing the number of cables in your deployment. With the Device Connector, you can connect IP cameras and other equipment over long distances or even have devices communicate directly with each other. The Device Connector provides fast and reliable connectivity over Wi-Fi with its unique ability to bond both 2.4GHz and 5GHz channels, while PepVPN ensures that your information is absolutely safe.
AP One
Peplink AP one industrial networking
Fast, Secure, Long-Range Wi-Fi
Wi-Fi access points in numerous form factors, all capable of ad delivery support and centrally manageable via InControl 2.
AP Pro
Peplink Ap Pro IP67 weatherproof
IP67 All-Weather Wi-Fi Solution
Deliver fast and reliable Wi-Fi in even the harshest conditions. Features a sealed, all-metal IP67 enclosure for years of dependable operation.
Device Connector
Pepwave Device Connector Industrial Wi-Fi Bridge
Wi-Fi / Ethernet Adapter
Combine both 2.4GHz and 5GHz channels for maximum bandwidth and reliability. Connect any Ethernet-only device while boosting your Wi-Fi coverage.
