Device Connector Rugged
Vendor Neutral Wireless Bridge. Extends SpeedFusion to Wi-FI
The Device Connector Rugged enables Ethernet devices to access wireless networks with unbreakable reliability. Using our signal bonding technology, Ethernet devices can connect using the combined bandwidth of 2.4GHz and 5GHz frequency Wi-Fi in a single LAN connection. The Device Connector is compatible with any access point, so you can just drop it in and go – no network reconfiguration or device upgrades needed.
2.4 5GHz IndoorOutdoor Wireless Bridge #2
Use Cases
Industrial
Healthcare
Hospitality
SpeedFusion Between Wi-Fi and Landline
Sample Topology
2.4 5GHz IndoorOutdoor Wireless Bridge #4
The Device Connector can combine a wired landline connection and a Wi-Fi connection. This configuration provides extra connection resilience and diversity: if one connection breaks, the other can still take over.
Consistent Wi-Fi Coverage & Reliable Connectivity
Plug-and-Play
Easily extend Wi-Fi coverage in minutes with Pepwave’s Device Connector Rugged. The Device Connector gets your devices talking over a large area without wires or configuration headaches. And because it works transparently at Layer 2, the Device Connector is compatible with any access point.
Merge 2.4GHz & 5GHz Signals
Normally, Wi-Fi devices will force you to choose between 5GHz or 2.4GHz. With the Device Connector Rugged, you can have both. Simply connect your device to the Ethernet port and the device connector will combine 5GHz and 2HGz into a single reliable connection.
Advanced Roaming
Advanced Roaming lets your Device Connector Rugged seamlessly hop from AP to AP in a matter of seconds. Whether you’re commanding an emergency situation, coordinating a construction project, or keeping your warehouse stocked, Advanced Roaming keeps everyone communicating at all times.
  • Wi-Fi Interface802.11ac/a/b/g/n 3x3 MIMO
    Ethernet Port2x GE
    Data Rate3x3 MIMO,
    2.4GHz: 450Mbps,
    5GHz: 1300Mbps
    Transmit Power2412 - 2472 MHz: 24dBm (FCC)/17dBm (CE)
    5180 - 5825 MHz: 22dBm (FCC)/17dBm (CE)
    Maximum Concurrent Users60
    EnclosureIndoor Metal
    Dimensions5.8 x 5.0 x 1.6 inches |
    147 x 128 x 40 mm
    Weight0.96 pounds |
    435 grams
    PoE Input802.3af
    Power InputDevice: 12V - 36V DC
    AC Adapter: AC Input 100V – 240V / DC Output 12V
    Terminal Block: 12V - 36V DC
    802.3af PoE (Injector Not Included)
    Power Consumption13W (max.)
    Operating Temperature-4° – 149°F |
    -20° – 65°C
    CertificationsFCC, CE, RoHS
    Warranty1-Year Limited Warranty
  • NetworkBridge Mode
    Router (NAT) Mode
    RadioMultiple SSID
    Transmit Power Adjustment
    Client AuthenticationEAP-TTLS/EAP-PEAP/EAP-TLS
    CHAP/MSCHAP/MSCHAPV2/PAP
    EAP Outer Authentication Identity
    RADIUS Server with Certificate Authentication
    AP SecurityOpen
    WPA-PSK/RADIUS
    WPA2-PSK/RADIUS
    Complete VPN Solution PepVPNSite-to-Site VPN
    256-bit AES Encryption
    Pre-shared Key Authentication
    Dynamic Routing
    InControl Cloud Management
    SNMP v1, v2c and v3
    Power RequirementsUniversal Input
    802.3at PoE+
    • Device
    • 12V2A Power Supply
    • 3x Dual-Band 5dBi Omni Antenna
  • Product Code
    Product Name
    Description
     DCS-RUG
       802.11ac/a/b/g/n layer 2 client bridge in metallic indoor enclosure. Manageable by InControl cloud management.
