MAX HD2 Dome
Dual Cellular Router for Mobile Outdoor Deployments
The HD2 Dome provides dual-cellular Bandwidth Bonding in an IP67 enclosure that has a minimal profile on the rooftop while providing maximum signal. With redundant SIM, the HD2 Dome supports two cellular radios and four SIM cards. Combine the HD2 Dome with the SIM Injector, and the number of cards increases to twelve.
Dual-Cellular Outdoor Router MAX HD2 DOME #2
Compatible With:
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #10
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #3
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #5
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #8
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #4
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #9
Topologies
Minimum Cable Loss, Best Cellular Signal Quality
Most outdoor deployments require a centrally placed router attached to strategically placed antennas. With the HD2 Dome, the antennas are placed in the same integrated enclosure as the cellular radios. This arrangement minimizes cable loss, giving you the best signal possible.
Simple Installation Running a Single Ethernet Cable
The HD2 Dome has a M35 screw mount, and only requires a single Ethernet cable to install. For wall or pole mounted deployments, the HD2 Dome comes with an Ethernet splitter and a mounting rack that provides a multitude of installation options.
Dual-Cellular Outdoor Router MAX HD2 DOME #8
8 Additional SIM With the SIM Injector
With the addition of the SIM Injector, the HD2 Dome can support up to 12 SIM at your fingertips. Simply connect an Ethernet cable between the SIM Injector and the HD2 Dome. The SIM Injector is capable of PoE output, so you don’t need to add another PoE switch to your deployment.
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD2 Dome supports band 14, providing additional coverage as the situation demands.
Dual-Cellular Outdoor Router MAX HD2 DOME #9
Certified Toughness
In addition to rugged metal enclosure, the MAX HD2 Dome is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
(Upon Request)
Railway Applications
(EN 50155)
(Upon Request)
Electromagnetic Compatibility
(EN 61000)
Dual-Cellular Outdoor Router MAX HD2 DOME #10
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Multiple Mounting Options
The HD2 Dome offers significant deployment flexibility due to its modular construction. By itself, it has an M35 thread, making it easy to mount on top of any pole or on the rooftop of any vehicle.
The HD2 Dome comes with an Ethernet splitter that enables an additional GE LAN output. With the splitter installed, the HD2 Dome can then be used with the included mounting bracket to fix onto any wall, or to securely tie onto any pole.
The HD2 Dome, Ethernet splitter, and the mounting bracket are all included, so you can deploy this device just about anywhere.
Dual-Cellular Outdoor Router MAX HD2 DOME #11
SIM Injector – More SIM, More Range
Together, the HD2 Dome and SIM Injector can make deployments significantly easier to set up and manage.
    SoftwarePepwave MAX Firmware
    WAN CellularSupport for DHCP
    WAN Link Health Check
    Bandwidth Allowance Monitor
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    Weighted
    Enforced
    Persistence
    Priority
    Overflow
    Least Used
    Lowest Latency
    Fastest Response Time
    Complete VPN SolutionSpeedFusion VPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding
    Site-to-Site VPN
    Bandwidth Aggregation
    Hot Failover
    256-bit AES Encryption
    Pre-shared Key Authentication
    Dynamic Routing
    X.509 Certificate Support
    PPTP VPN Server
    RADIUS, LDAP Authentication
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    VRRP HA support
    SecurityStateful Firewall
    DoS Prevention
    Web Blocking
    Advanced QoSUser Groups
    Bandwidth Reservation
    Individual Bandwidth Limit
    Application Prioritization
    By User Groups
    SIP, HTTPS, VPN QoS
    Custom Application QoS
    Wi-Fi Usage Statistics
    Support RADIUS Authentication
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    *IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
  • Product CodeCarrierEmbedded Modem4G Bands3G Bands
    MAX-HD2-DOM-M-LTE-EAPAC & EMEA/
    CAT- 4
    2B1, B3, B7, B8, B20WCDMA/HSPA+/DC-HSPA+:
    B1, B2, B5, B6, B8
    MAX-HD2-DOM-M-LTEA-BDAPAC & EMEA/
    Cellular 1 (CAT-6)
    Cellular 2 (CAT-12)
    2Cellular 1:
    B1, B2, B3, B4, B5, B7, B8, B12, B13, B14,
    B30, B38, B39, B40, B41, B42, B43, B48,
    B66, B71
    Cellular 2:
    B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
    B14, B17, B18, B19, B20, B21, B25, B26,
    B28 , B29, B30, B32, B38, B39, B40, B41,
    B66
    Cellular 1:
    HSPA+/WCDMA: B1, B2, B4, B5, B6, B8,
    B9, B19
    Cellular 2:
    HSPA+: B1, B2, B3, B4, B5, B8, B9, B19
    MAX-HD2-DOM-M-LTEA-KGlobal /
    CAT-12
    2B1, B2, B3, B4, B5, B7, B8, B9,
    B12, B13, B18, B19, B20, B26, B28, B29, B30,
    B32, B41, B42, B43, B46, B48, B66
    HSPA+: B1, B2, B4, B5, B6, B8, B9, B19
  • Product CodeDescription
    ACW-112Waterproof Ethernet Adaptor (learn more)
    SIM-BK8-4E-56VSIM Injector
    ACW-650Mobility thread to HD Dome
    ACW-6511″ 14TPI female to Mobility thread
    ACW-6531 1/4″ 11 TPI Male Adapter
    ECP-MAX-HD2-DOM-LTEA-1YEssentialCare+ (1-Year) for MAX HD2 Dome LTEA
    ECP-MAX-HD2-DOM-LTEA-2YEssentialCare+ (2-Year) for MAX HD2 Dome LTEA
    ECP-MAX-HD2-DOM-LTEA-4YEssentialCare+ (4-Year) for MAX HD2 Dome LTEA
    SVL-4711-Year EssentialCare for MAX HD2 Dome LTEA
    SVL-5752-Year EssentialCare for MAX HD2 Dome LTEA
    • MAX HD2 Dome
    • Ethernet Splitter
    • 2x Waterproof Ethernet Connector (ACW-112)
    • Mounting Kit Set
