Use Cases
Shock and vibration resistance
(EN 61373:2010)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The MAX Transit supports band 14, providing additional coverage as the situation demands.
Simultaneous
Dual-Band 11ac Wi-Fi
Reduce Wi-Fi congestion and interference. Simultaneous dual-band Wi-Fi gives you two independent networks that also work together, maximizing the throughput that your passengers can enjoy.
Compatible With:
Compatible on all major carriers. Certified with Verizon* and T-Mobile.
*Not applicable to 5G SKU.
Install it Anywhere
With DIN rail mounts and mounting ears that can be installed from many angles, the MAX Transit is ready to fit into just about any space you have available.
