Compatible With:
Certified Toughness
In addition to rugged metal enclosure, the MAX Transit Duo has certifications on:
Shock and vibration resistance
(EN 61373:2010)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The MAX Transit Duo supports band 14, providing additional coverage as the situation demands.
Dual Embedded Cellular Modems
The MAX-TST-DUO has up to two cellular modems and two redundant SIM slots, allowing you to use up to four different cellular providers for bandwidth bonding, data overage protection or eliminating blind spots.
Simultaneous
Dual-Band 11ac Wi-Fi
Reduce Wi-Fi congestion and interference. Simultaneous dual-band Wi-Fi gives you two independent networks that also work together, maximizing the throughput that your passengers can enjoy.
Get it all with PrimeCare
SpeedFusion
InControl2
Warranty
PrimeCare makes SpeedFusion networks easier to build. It bundles InControl, Warranty, SpeedFusion licence upgrades, FusionHub licenses into one subscription.
