Use Cases
Public Safety & First Responders
Passenger Wi-Fi
Telemedicine
Compatible With:
Simplify your Deployments
Cut down on cabling and simplify your deployments with MAX HD2. The HD2 includes a built-in 4-port GE LAN switch, reducing clutter and the need for extra equipment. As well as a terminal block for secure power installation in vehicles and other locations.
802.11ac Wi-Fi AP
Terminal Block for Secure Power Supply
Built-in 4-Port GE Switch
Dual Cellular for Multiple Carriers
MAX HD2 has two embedded cellular modems and dual SIM slots that allows you to use the same or different cellular providers for bandwidth bonding or for eliminating blind spots.
Certified Toughness
In addition to rugged metal enclosure, the MAX HD2 is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
RF Port Lightning Immunity
(ITU-T K.20 (+/- 1.5 kV))
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD2 supports band 14, providing additional coverage as the situation demands.
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With Social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
#PowerofPeplink
