Compatible With:
Topologies
Minimum Cable Loss, Best Cellular Signal Quality
Most outdoor deployments require a centrally placed router attached to strategically placed antennas. With the HD2 Dome, the antennas are placed in the same integrated enclosure as the cellular radios. This arrangement minimizes cable loss, giving you the best signal possible.
Simple Installation Running a Single Ethernet Cable
The HD2 Dome has a M35 screw mount, and only requires a single Ethernet cable to install. For wall or pole mounted deployments, the HD2 Dome comes with an Ethernet splitter and a mounting rack that provides a multitude of installation options.
8 Additional SIM With the SIM Injector
With the addition of the SIM Injector, the HD2 Dome can support up to 12 SIM at your fingertips. Simply connect an Ethernet cable between the SIM Injector and the HD2 Dome. The SIM Injector is capable of PoE output, so you don’t need to add another PoE switch to your deployment.
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD2 Dome supports band 14, providing additional coverage as the situation demands.
Certified Toughness
In addition to rugged metal enclosure, the MAX HD2 Dome is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
(Upon Request)
Railway Applications
(EN 50155)
(Upon Request)
Electromagnetic Compatibility
(EN 61000)
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Multiple Mounting Options
The HD2 Dome offers significant deployment flexibility due to its modular construction. By itself, it has an M35 thread, making it easy to mount on top of any pole or on the rooftop of any vehicle.
The HD2 Dome comes with an Ethernet splitter that enables an additional GE LAN output. With the splitter installed, the HD2 Dome can then be used with the included mounting bracket to fix onto any wall, or to securely tie onto any pole.
The HD2 Dome, Ethernet splitter, and the mounting bracket are all included, so you can deploy this device just about anywhere.
SIM Injector – More SIM, More Range
Together, the HD2 Dome and SIM Injector can make deployments significantly easier to set up and manage.
Software Pepwave MAX Firmware WAN Cellular Support for DHCP
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
Weighted
Enforced
Persistence
Priority
Overflow
Least Used
Lowest Latency
Fastest Response Time
Complete VPN Solution SpeedFusion VPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding
Site-to-Site VPN
Bandwidth Aggregation
Hot Failover
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
X.509 Certificate Support
PPTP VPN Server
RADIUS, LDAP Authentication
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
VRRP HA support
Security Stateful Firewall
DoS Prevention
Web Blocking
Advanced QoS User Groups
Bandwidth Reservation
Individual Bandwidth Limit
Application Prioritization
By User Groups
SIP, HTTPS, VPN QoS
Custom Application QoS
AP Controller AP Controller Support
Wi-Fi Usage Statistics
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
*IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
Product Code Carrier Embedded Modem 4G Bands 3G Bands MAX-HD2-DOM-M-LTE-E APAC & EMEA/
CAT- 42 B1, B3, B7, B8, B20 WCDMA/HSPA+/DC-HSPA+:
B1, B2, B5, B6, B8MAX-HD2-DOM-M-LTEA-BD APAC & EMEA/
Cellular 1 (CAT-6)
Cellular 2 (CAT-12)
2 Cellular 1:
B1, B2, B3, B4, B5, B7, B8, B12, B13, B14,
B30, B38, B39, B40, B41, B42, B43, B48,
B66, B71
Cellular 2:
B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
B14, B17, B18, B19, B20, B21, B25, B26,
B28 , B29, B30, B32, B38, B39, B40, B41,
B66Cellular 1:
HSPA+/WCDMA: B1, B2, B4, B5, B6, B8,
B9, B19
Cellular 2:
HSPA+: B1, B2, B3, B4, B5, B8, B9, B19MAX-HD2-DOM-M-LTEA-K Global /
CAT-122 B1, B2, B3, B4, B5, B7, B8, B9,
B12, B13, B18, B19, B20, B26, B28, B29, B30,
B32, B41, B42, B43, B46, B48, B66HSPA+: B1, B2, B4, B5, B6, B8, B9, B19 -
Product Code Description ACW-112 Waterproof Ethernet Adaptor (learn more) SIM-BK8-4E-56V SIM Injector ACW-650 Mobility thread to HD Dome ACW-651 1″ 14TPI female to Mobility thread ACW-653 1 1/4″ 11 TPI Male Adapter ECP-MAX-HD2-DOM-LTEA-1Y EssentialCare+ (1-Year) for MAX HD2 Dome LTEA ECP-MAX-HD2-DOM-LTEA-2Y EssentialCare+ (2-Year) for MAX HD2 Dome LTEA ECP-MAX-HD2-DOM-LTEA-4Y EssentialCare+ (4-Year) for MAX HD2 Dome LTEA SVL-471 1-Year EssentialCare for MAX HD2 Dome LTEA SVL-575 2-Year EssentialCare for MAX HD2 Dome LTEA -
- MAX HD2 Dome
- Ethernet Splitter
- 2x Waterproof Ethernet Connector (ACW-112)
- Mounting Kit Set
