Balance 210
Protecting your Business Continuity
2 WAN Ports
150 Users
350Mbps Router Throughput
Peplink ‘s line of products includes features that make your enterprise deployment easier and increase your network reliability and security in several ways. Boost network data rates, reliability, and flexibility while slashing connectivity costs with Peplink SD-WAN technology designed for multi-WAN link load balancing. Use Load Balancing and SpeedFusion bandwidth bonding to deliver superfast VoIP, video streaming, and data using an SD-WAN enabled network.
Branch/Small Office
Small Business
Mid-Size Business
Large Enterprise/Campus
Cloud/VM
With the help of WAN smoothing network traffic will be assigned to WAN connection with the lowest latency. Use multiple WAN connections to create a single, jitter-free data streem.
Built to Last
Balance 210 is supported by InControl, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
Web Admin Demo
#PowerofPeplink
