InControl 2 Requirements
Supported Devices
InControl 2 supports the following devices. We will be adding support for additional devices and device families in the near future.
ModelInControl 2 Supported
Peplink Balance *
Peplink MediaFast
Pepwave MAX
Pepwave AP ^
Pepwave Device Connector spec_none
Pepwave Surf #
Peplink FusionHub
Peplink Switch
* Not available in hardware revision 1 of Balance 210 and 310; and hardware revision 1 of Balance 30.
^ Supports devices running Firmware 3.4.1 and above.
# Supports Surf SOHO and Surf On-The-Go.
System Requirements
To be managed by InControl 2, your device must be:
  • One of the compatible devices listed above
  • Running Firmware 6.1 or 3.4.1
  • In-warranty or covered by InControl 2 Subscription
Warranty Status
Firmware 6.1 and 3.4.1 is free for in-warranty devices, but you will need to purchase warranty to upgrade out-of-warranty devices. If you are unsure of your device’s warranty status, check by adding the device to InControl 2. Even if the device cannot be managed by InControl 2 (e.g., the device runs older firmware), InControl 2 will still show the device’s warranty status.
My device meets InControl 2 Requirements
