Supercharged Private 5G/LTE Networks
Privacy. Efficiency. Security
Private cellular networks, also known as CBRS (Citizens Broadband Radio Service) in the US, are designed for remote reliability. Coming in rugged enclosures with a host of management features, our devices work well in supplementing these networks. Easily deploy private networks that are ideal for commercial, manufacturing, emergency services, remote sites, campuses, and small-scale LTE networks.
Challenges
Congestion
Wireless networks are prone to congestion, leading to packet loss and interrupted sessions, especially in densely populated areas.
Latency
Real time applications such as VoIP calls require a low latency connection. Heavy usage on the same network could greatly affect the quality of your connection
Remote Connectivity
Even with the best technology and investment, cellular dead zones are inevitable in less urban areas
Security
Without proper security, networks are exposed to outside threats and may lead to the theft of confidential information
The Big Picture
The Big Picture of a CBRS network where Peplink serves as the router or access point.
Technology
Hot Failover
Seamless Roaming
Bandwidth Bonding
Bandwidth Overflow
Seamlessly failover to backup connections when network disruptions occur. This protects your important sessions and keeps you connected.
Private 5G/LTE and Wi-Fi work together by seamlessly transitioning between the two types of connections to enhance coverage, improve reliability, and ensure your persistent sessions aren’t interrupted as you move around.
Combine the bandwidth of multiple connections together into a single bandwidth pipeline to accommodate for bandwidth heavy applications.
Optimize your connection by monitoring bandwidth usage and switching to the most suitable connection as the situation changes. Switch to high bandwidth connections during peak hours and less costly connections during periods with low usage.
Benefits of Private 5G/LTE Networks
Education
A private cellular network would allow schools to broadcast their intranet across their entire region. Students would be able to access school resources from home, providing an equal opportunity educational environment for the entire community.
Healthcare
Increased security and a high bandwidth capacity is a must for emergency services. A private cellular network ensures large volumes of personal data are transferred quickly and securely. Professionals will also be able to access to essential information and reports in a timely manner.
Manufacturing
A large amount of IoT devices and automated machinery in the same Wi-Fi network could lead to network congestion. A private cellular network opens up the air waves to ensure important equipment won’t lose connection and can continue communicating in real time.
Featured Products
Single Cellular devices
  • A cost-effective solution with an easily scalable network for future growth.
  • Beneficial for companies that have plenty of IoT devices in their network
  • Experience a supercharged network with flexible network options
  • Featured products: Balance 20X, BR1 Mini HW3, HD1 Dome
    *See the full list of compatible devices under the FAQ session
Multi Cellular devices
  • Use multi-cellular devices to further supercharge your private LTE network
  • Use multiple connections at the same time for a network with zero down-time
  • Reach high speeds in low signal areas by creating a mega-bandwidth channel
  • Featured products: Transit Duo Pro, HD4 MBX, Balance 310 5G
5G devices
  • Enjoy ultra low latency private 5G networks with the power of 5G
  • Bond multiple 5G connections for a reliable supercharged network
  • Automatically configure the best network settings for any situation with a single click
  • Featured products: HD1 Dome Pro, BR2 Pro, SDX Pro (with EXM-2X5G)
  • Q. Will higher priority tiers interrupt my private LTE network?
    Unfortunately yes, especially if you are located near US Naval bases. However, you can avoid any downtime caused by these interruptions with SpeedFusion as long as you have a backup connection.
    Q. Can a private LTE network be built on Peplink products?
    Yes and no. Our devices connect user devices to LTE networks but cannot build an LTE network directly. This is why we have partnered with Ericsson to be able to provide a complete solution for private LTE networks.
    Q. Which Peplink devices work in a CBRS network?
    Below is a list of our single cellular CBRS-capable devices.
    MAX BR1 HW3 MAX-BR1-MINI-LTEA-US-T-PRM, MAX-BR1-MINI-LTEA-US-DC-T-PRM
    MAX BR1 ENT MAX-BR1-ENT-LTEA-R-T
    MAX BR1 Pro CAT-20 MAX-BR1-PRO-GLTE-S-T-PRM
    MAX BR1 Pro 5G MAX-BR1-PRO-5GD-T-PRM
    HD1 Dome MAX-HD1-DOM-M-GLTE-G, MAX-HD1-DOM-M-GLTE-S
    HD1 Dome Pro MAX-HD1-DOM-PRO-5GD
    FlexModule Mini of Balance 20X,
    Balance 380X, Balance 580X
    EXM-MINI-LTEA-US, EXM-MINI-1LTEA-R, EXM-MINI-1LTEA-D, EXM-MINI-1GLTE-G, EXM-MINI-GLTE-S
    Balance 20X BPL-021X-LTEA-US-T-PRM, BPL-021X-LTEA-B-T-PRM
    Balance 20X LoRaWAN BPL-021X-LTEA-US-T-PRM, BPL-021X-LTEA-B-T-PRM
    Balance 310X BPL-310X-LTEA-R-T, BPL-310X-GLTE-S-T
    Balance 310 Fiber 5G BPL-310-FBR-5GD-T-PRM
    Below is a list of our multi cellular CBRS-capable devices.
    MAX BR2 Pro MAX-BR2-PRO-5GD-T-PRM
    MBX MAX-HD2-MBX-LTEA-R-T, MAX-HD2-MBX-GLTE-S-T, MAX-HD4-MBX-LTEA-R-T, MAX-HD4-MBX-GLTE-S-T, MAX-HD2-MBX-5GD-T
    MBX Mini MAX-MBX-MINI-5GD-T
    HD2 Dome MAX-HD2-DOM-M-LTEA-BD, MAX-HD2-DOM-M-LTEA-K
    PDX PDX-EC-LTEA-R-T, PDX-EC-LTEA-K-T
    HD2 IP67 MAX-HD2-M-LTEA-R-IP67, MAX-HD2-M-LTEA-WF-IP67, MAX-HD2-M-LTEA-WK-IP67
    FlexModule of EPX, SDX Pro, SDX EXM-3LTEA-R, EXM-4LTEA-R, EXM-2GLTE-S
    UBR Plus UBR-PLUS-LTEA-US-T-PRM, UBR-PLUS-LTEA-B-T-PRM
    Transit Duo Pro MAX-TST-PRO-DUO-LTEA-USR-T-PRM
    Balance 310 5G BPL-310-5GD-D-T-PRM
    Below is a list of our 5G CBRS-capable devices*.
    MAX BR1 Pro 5G MAX-BR1-PRO-5GH-T-PRM
    MAX BR2 Pro MAX-BR2-PRO-5GH-T-PRM
    MBX 5G MAX-HD2-MBX-5GH-T
    MBX Mini MAX-MBX-MINI-5GH-T
    HD1 Dome Pro MAX-HD1-DOM-PRO-5GH
    FlexModule Mini of Balance 20X, Balance 380X, Balance 580X EXM-MINI-15GH
    FlexModule of EPX, SDX Pro, SDX EXM-2X5GH
    Balance 310 Fiber 5G BPL-310-FBR-5GH-T-PRM
    Balance 310 5G BPL-310-5GH-K-T-PRM, BPL-310-5GH-R-T-PRM
    Balance 310X 5G BPL-310-5GH-K-T-PRM, BPL-310-5GH-R-T-PRM
    Balance 310X 5G BPL-310-5GD-D-T-PRM
    *5GH modules support 5G private 5G/LTE networks with special firmware
