A Connection that Stays While You’re on the Go
5G Antennas | Wireless Internet
One of the most popular applications of an outdoor antenna is for recreational vehicles; whether it be for working remotely, a camping trip, or journeying on the road. Mostly, RV users cannot depend on cabled internet and, as a result, need devices to meet their mobile needs. The following is an example of how the needs of an RV user were fulfilled by Peplink’s Mobility antenna, which was designed to deliver a steady connection, especially for mobile deployments.
An American couple lives in and works out of their RV full-time on the road, moving every few weeks. With their daily activities being carried out in their vehicle, they needed a solution that allowed easy set-up and brought dependable internet connectivity.
The Original and New Setup
Their original set-up involved using multiple Wi-Fi boosters and hotspots, with an antenna installed on the vehicle’s roof. Though this framework worked for some time, the couple found this connectivity solution inefficient. It required time to set up the internet connection at each new location. What’s more, it did not have any built-in redundancies when one connection failed.
To solve these, they tried Peplink’s solution, which included deploying a MAX Transit Duo along with a Mobility 42G Antenna. With the MAX Transit Duo’s Hot Failover technology, any open session will automatically and seamlessly switch networks when the primary SIM fails. Bandwidth Bonding technology then combines the network bandwidths of two cellular modems and two redundant SIM slots, for greater speeds.
Additionally, the Mobility 42G Antenna has a high gain for local coverage and is comparatively smaller than its competitors. Its versatile installation feature also makes it easy to complete the arrangement. With this solution, the couple is able to stay connected whenever on the move and wherever the road takes them.
Peplink’s MAX Transit Duo along with the Mobility 42G provided unbreakable connectivity for this couple’s mobile home. The Mobility antenna series introduces a line of antennas that cater to many different needs, all easy to set up and get connected, just like on an RV.
The Max Transit Mini
MAX Transit Duo
  • Deployed in the RV to provide on-the-go connectivity.
  • Dual embedded cellular modems and two redundant SIM slots for up to four cellular providers.
  • Hot Failover automatically and seamlessly switches open session to working connection.
  • The MAX Transit Duo is paired with a Mobility 42G Antenna.
  • 5G ready 4×4 cellular MIMO for high bandwidth and solid reliability.
  • The GPS receiver is equipped with high gain LNA, making it ideal for location tracking.
What’s More
Read our article on Gaining the Most from your Antenna
[Article] Gaining the Most from your Antenna
Read our article on What Makes or Breaks an Antenna
[Article] What Makes or Breaks an Antenna?
Read our case study on the Mobility antenna series
[Article] Bringing the Mobility Antenna Series to Life
Watch our webinar on Peplink products for RVs
[Webinar] Your Guide to Peplink for RVs
