Amazon Transit Gateway Connect
Seamlessly integrate between SpeedFusion branch networks and AWS cloud applications.
Simplify Your Network, Cut Operating Costs
Instead of setting up peer-to-peer VPN connections to each cloud application, you can now reach them all using a single connection to an Amazon Transit Gateway.
How It Works
Amazon Transit Gateway is a cloud router that connects all your VPCs, centralizing your AWS network. Amazon Transit Gateway Connect is the technology that enables you to connect a VPC hosting FusionHub to the Amazon Transit Gateway using a Standard GRE tunnel with 5Gbps of bandwidth.
InControl Setup Guide for Managing FusionHub & AWS Transit Gateway Connections
FusionHub on AWS allows you to establish SpeedFusion connections between AWS VPC and on-premise Peplink devices. AWS Transit Gateway Connect and Peering Connection integration allows your on-premises networks in different worldwide locations to connect through AWS Cloud and be able to access other services on AWS.
This guide contains:
• Provisioning Transit Gateway / Connect / Peering Connect, VPC route table by InControl
• Provisioning AWS Global Network by InControl
• Provisioning GRE and BGP settings to Peplink FusionHub
About AWS Transit Gateway: What’s AWS Transit Gateway | AWS Transit Gateway Partners
