PePLink Balance 710
PePLink Balance 710
Business Continuity with No Compromises
PePLink Balance 710 helps protect your business continuity by seamlessly connecting your business to the Internet through multiple independent links, and intelligently managing the links to provide automatic failover and enhanced performance.
How is it different?
PePLink offers the only affordable link load balancers with advanced, enterprise-grade features.
 Features Benefits
Link Aggregation & Load BalanceFaster, more reliable Internet made easy.
Enterprise-Grade PerformanceMaximum throughput of 350M housed in a 1U, 19" rack-mountable unit.
Drop-in Mode Easy, transparent installation
Integrated DNSSupport of NS, A, MX, CNAME and TXT records
VoIP, SIP, and Vonage® Support Fully compatible with major SIP-based VoIP providers. Enjoy your calls.
QoS for VoIP Better and clearer sound quality for your voice calls.
Session Binding Compatible with secure web, e-banking, and other applications.
Inbound Load Balancing Optimal use of all available links for incoming requests to your servers.
Hardware High Availability Utmost service protection by deploying two PePLink Balance devices side-by-side with VRRP
    Proprietary Site-to-Site VPN Secure and aggregate VPN traffic across all WAN connections between two locations.
Will it work in my environment where I have a ...?
We have compiled a few common setups for your reference. You can also find more technical reading in the resources area. If you still have questions, feel free to contact us.
Which model should I buy?
The Balance product family differs in the number of WAN ports and throughput. For details and our recommendation, please read this FAQ.
What about support?
Included free of charge with every PePLink Balance device is the Standard Support Service that provides unlimited email support with a 24-hour response time. Also available is the optional One-year Priority Support Service that provides unlimited email support with a 12-hour response time, and telephone support on escalated issues. Details here.
PePLink Balance is also backed by a one-year limited warranty and lifetime firmware upgrade plan. Details here.
We do our best to ensure your satisfaction with PePLink Balance. In the unlikely event that PePLink Balance does not fit your needs, your investment is protected by our 30-Day Money Back Guarantee.
- All registered trademarks are properties of their respective owners.
Enterprise-scale Link Aggregation and Outbound Load Balance
  • Seven WAN and Gigabit - Direct-connect up to 7 Internet links; The LAN port and 3 (out of 7) WAN ports are Gigabit-enabled.
  • Aggregation, Load Balance and Failover - Bandwidth combination enhances throughput; multiple Internet links provide redundancy, load sharing and improve network availability.
  • Durable Enclosure - Housed in a 1U, 19" rack-mountable chassis for business-critical environments.
Ease of Use and Management
  • Drop-in Mode - Deployment of PePLink Balance in Drop-in Mode does not require any changes to existing network devices. This is best suited for customers that already have a router and firewall in place.
  • Web Management Interface - PePLink Balance is managed through an elegant and modern web interface.
  • Traffic Reporting - PePLink offers customers a free (and optional) service to gather and visually present traffic statistics for your network.
Maximum Network Uptime
  • Intelligent Health Checks and Automatic Failover - Regular health checks (PING or DNS queries) ensure up-to-date link statuses. In case of a link failure, PePLink Balance automatically re-routes traffic to a healthy link to provide continuous Internet service.
  • On-the-fly Configuration Activation - Settings can be changed and activated on PePLink Balance without system reboot.
  • Dual Firmware Architecture - Protect customers from risks associated with upgrades, e.g. power outage; offer flexibility and fast fallback with new firmware releases.
  • Hardware High Availability (HA) - A pair of PePLink Balance units can be deployed in an Active/Hot-standby HA hardware configuration via VRRP, Virtual Router Redundancy Protocol. In case of failure with the Active unit, the Hot-standby unit becomes active, and provides continuous service.
Best-in-Class Functionalities
  • Integrated Authoritative DNS and Inbound Load Balance – Increase available bandwidth for your Internet services on the fly. The built-in authoritative DNS server supports MX, NS, A, CNAME, and TXT records. You can easily load balance incoming requests and traffic among all available links.
  • Enhanced Video, Audio and VoIP - With the ability to control quality of service for VoIP, SIP, and Streaming Video applications, PePLink Balance ensures consistent throughput of audio, video and other delay-sensitive traffic through prioritized delivery.
  • SIP and Vonage Support - Out of the box support for SIP-based VoIP applications, such as Vonage®; PePLink Balance intelligently detects and transparently manages voice sessions across all of the available Internet links.
  • Multiple WAN IP and Subnet Support - Support for multiple Internet IP addresses from each ISP, so that services continue to be available in event of a link failure.
  • One-to-one NAT - PePLink Balance offers the ability to map specific public IP addresses for outbound requests from different internal servers.
  • Stateful Firewall - PePLink Balance provides a rule-based firewall that supports an unlimited number of rules.
  • Site-to-Site VPN - PePLink proprietary site-to-site VPN that secures and aggregates VPN traffic across all WAN connections. Currently, it supports a pair of Balance 380/700/710 units used between two locations.
Comprehensive Traffic Control
  • Policy-based Management - A flexible Outbound Traffic Manager allows you to define policy rules to control traffic based on any combination of IP source, destination, port and MAC address.
  • Weighted Load Distribution - Outbound traffic can be distributed over the available Internet links based on configurable proportions. Proportions among various traffic types can be independently configured according to protocol and port number.
  • Session Persistence/Binding - PePLink Balance supports Internet services, such as secure web, that require clients to maintain the same IP address throughout a session.
  • Priority - With this algorithm, you can define traffic to pass through the links with priority. When a link with a higher priority is available, it will always be used.
  • Enforced/Nailed - You can define traffic to be nailed to a particular connection even in the event that it is down.
Functionality and Compatibility
LAN
  • Built-in DHCP Server for LAN Clients
WAN
  • DHCP, PPPoE, GRE, and Static IP
  • Inbound and Outbound Link Load Balance
Routing
  • NAT and IP Forwarding
  • Configurable Static Routes
DNS Server
  • Built-in authoritative DNS server with support for MX, NS, A, CNAME, and TXT records
Security
  • Rules-based Stateful Firewall, with IP Address, Protocol, and Port Filtering
  • DMZ (Demilitarized Zone)
Device Management
  • Wizard & Menu Driven Web-based Management Interface over HTTP / HTTPS
  • Remote Reporting and Management
  • Configuration Upload and Download
Hardware Specification
LAN Interface
  • 1 Gbps Ethernet Port (10/100/1000Base-T)
WAN Interface
  • 7 Ethernet Ports
    (3 x 10/100/1000Base-T, 4 x 10/100base-T)
Universal AC Power Adapter
  • 100-240V
Power Consumption
  • 70W (Max.)
Certifications
  • FCC, CE
Form Factor and Miscellaneous
Dimensions
  • 1U Rackmount Chassis
  • 426(W) x 379.8(D) x 43.5(H) mm
    16.8"(W) x 14.95"(D) x 1.72"(H) inch
Weight
  • 5.5kg (12.1 lb)
Operating Environment
  • Operating temperature:
    0°C to 40°C (32°F to 104°F)
  • Relative Humidity:
    10% to 90% (Non-condensing)
Warranty
  • One-year Limited Warranty
Datasheets
Post Date Title Type Size Download
Jan 24 2008 Balance 200/300/380/710 Datasheet 518KB
Application Notes
Jan 29 2007 Drop-in Operational Mode (Technical) 100KB
Jan 29 2007 Inbound Link Load Balancing (Technical) 342KB
Aug 2 2007 Balance in Hospitality Environments 245KB
Jan 29 2007 Balance for Schools 100KB
Jan 29 2007 Balance for Wireless Hot Spots 104KB
Jan 29 2007 VoIP Applications of PePLink Balance 235KB
Feb 1 2007 Dual FLASH and the Benefits 208KB
How-to Documents
May 23 2007 Set up Drop-in Mode in 30 mins 517KB
Jan 29 2007 Drop-in Mode and Inbound Load Balance 803KB
Jan 29 2007 How to set up Integrated DNS Server for Inbound Load Balancing 667KB
Jan 29 2007 Enable Free Reporting Service 308KB
Mar 19 2007 High Availability Configuration by VRRP 449 KB
User Manual
Feb 28 2008 Balance User Manual 4.1 3.1MB
Case Studies
Oct 9 2007 TJSC Group Ltd. (London, UK) 725KB
Jun 6 2007 Spleen Web Hosting (Jacksonville, FL) 485KB
Apr 10 2007 Becker Limos (Oxnard, CA) 821KB
Mar 20 2007 Cressida Associates (Haworth, NJ) 520KB
Jan 26 2007 19th Avenue Lofts (Seattle, WA) 449KB
Jan 28 2007 Wisers Information (Hong Kong SAR) 160KB
Testimonials
PePLink is offering small businesses a very affordable and well-featured WAN load-balancing appliance.
Dave Mitchell
PC Pro Magazine (July 07)
United Kingdom
I am very impressed with your product. After unsuccessfully trying two of your competitors, I had the PePLink device up and running within 30 mins.
A. Blackledge
Future System Advisors
Louisiana (Jun 07)
Your products are incredibly effective and easy to use. Thanks for bringing such a useful device to the industry!
C. Clemens
Becker Automotive Design
California (Mar 07)
Best of the bunch!
J. Mehaffey
GPS Information
Georgia (Sept 06)
» More
Software Release (710)
Latest GA Firmware: 4.1.1
[History]
Released On: Apr 26, 2008
Download Now
Buy Online
We accept VISA, MasterCard, AMEX and PayPal for online order. If you have any concerns for online payment, you can also pay offline.
