Balance 380
Rock-Solid Performance
With 3 WAN connections and a combined total of 1 Gbps throughput, and a suite of advanced enterprise-class features, including Speedfusion bonding, the Balance 380 is an ideal solution for business environments.
1Gbps Multi-WAN (3 Ports) Router Balance 380 #2
Balance 380
Protecting your Business Continuity
  • 3 WAN Ports
  • High Capacity. 500 Users
  • 1 Gbps Throughput
  • Up to 100 VPN Peers*
*30 SpeedFusion Peers are enabled by default. 100 Peers can be activated with additional license (SFN-LC-100).
Peplink ‘s line of products includes features that make your enterprise deployment easier and increase your network reliability and security in several ways. Boost network data rates, reliability, and flexibility while slashing connectivity costs with Peplink SD-WAN technology designed for multi-WAN link load balancing. Use Load Balancing and SpeedFusion bandwidth bonding to deliver superfast VoIP, video streaming, and data using an SD-WAN enabled network.
  • Branch/Small Office
  • Small Business
  • Mid-Size Business
  • Large Enterprise/Campus
  • Cloud/VM
Combine the bandwidth of several mobile connections to form an ultra-fast data link. Sustain bandwidth-hungry and latency sensitive tasks without the need for fixed lines.
With the help of WAN smoothing network traffic will be assigned to WAN connection with the lowest latency. Use multiple WAN connections to create a single, jitter-free data streem.
1Gbps Multi-WAN (3 Ports) Router Balance 380 #5
Built to Last
Capable of years of uptime, the Balance  series easily handles monthly bandwidth that would crush lesser equipment. Every Peplink design is rigorously tested to exceed your expectations for speed, reliability, durability, and ease-of-use. We invest heavily in quality assurance and user experience testing to give you affordable, enterprise-class gear that just works, from the moment you take it out of the box.
Balance 380 is supported by InControl, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
Web Admin Demo
1Gbps Multi-WAN (3 Ports) Router Balance 380 #6
#PowerofPeplink
    SoftwarePeplink Balance Firmware
    WAN Link Health Check
    PING
    DNS Lookup
    HTTP
    Bandwidth Allowance Monitor
    IPv6 Support
    USB 4G/3G Modem Support
    changeip.com
    dyndns.org
    no-ip.org
    tzo.com
    DNS-O-Matic
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    -Weighted
    -Enforced
    -Persistence
    -Priority
    -Overflow
    -Least Used
    -Lowest Latency
    SecurityDoS Prevention
    Stateful Firewall
    Web Blocking
    Complete VPN SolutionSpeedFusion VPN/SpeedFusion Bandwidth Bonding
    -Site-to-Site VPN
    -Bandwidth Aggregation
    -Hot Failover
    -256-bit AES Encryption
    -Dynamic Routing
    -X.509 Certificate Support
    PPTP/L2TP/OpenVPN Server
    Advanced QoS User Groups
    -Bandwidth Reservation
    -Individual Bandwidth Limit
    Application Prioritization
    -By User Groups
    -SIP, HTTPS, VPN QoS
    -Custom Application QoS
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    BGP, OSPFv2 and RIPv2 Support
    Bonjour Forwarding
    Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi Usage Statistics
    Support RADIUS Authentication
    Support LDAP Authentication
    DNSBuilt-in Authoritative DNS
    -Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    Power RequirementsUniversal Input 100V – 240V AC
  • Product CodeProduct Description
    SFN-LC-100Up to 100 SpeedFusion Bonding License Key
    FIPS-LC-B380FIPS License for Balance 380
    ECP-BPL-380-1YEssentialCare+ (1-Year) for Balance 380
    ECP-BPL-380-2YEssentialCare+ (2-Year) for Balance 380
    ECP-BPL-380-4YEssentialCare+ (4-Year) for Balance 380
    SVL-7031-Year EssentialCare for Balance 380
    SVL-6082-Year EssentialCare for Balance 380
  • Product Code
    Product NameDescription
    BPL-380Balance 3803x GE WAN ports and 3x GE LAN ports. SpeedFusion capable
    • Balance 380
    • Power Cord (ACW-614)
    • 1 Pair of Mounting Brackets (ACW-382)
